iClone 8.4, 8.41 and 8.42 Official Issues Thread
Posted By Peter (RL) 2 Years Ago
3
4
5
6
7
K_Digital
K_Digital
Posted Last Year
Posts: 327, Visits: 1.4K
Oh no, thanks 4u2ges ! I havent noticed IC7/8 using different prop planes.
(even the display clearly indicated that, user error, i have updated my post)
Posted Last Year
Posts: 5.3K, Visits: 16.6K
In iClone 7 your plane has 2048 polygons (probably a Quad mesh plane)
In iClone 8 you are using a basic plane with 2 polygons. There is not enough mesh to tessellate.. thus the result.
K_Digital
K_Digital
Posted Last Year
EDIT: The below is a user error, though trying to follow the Manual using the same "square plane" from the iclone props results in the behave below.
https://manual.reallusion.com/iClone-8/Content/ENU/8.0/46-Tessellation-Displacement/Using_Grayscale_Images_for_Displacement.htm?Highlight=displacement
The issue occured because the Iclone 8 plane has only 2 polgons against 2048 in Iclone 7 (thanks to 4u2ges)
( I leave this here , someone else may meet the same circumstances , the tracker issue has been removed)
I asume this has not been fixed, so i put it here.
In IC8,32 / CC4,32 displacemant maps and Tessellation are not working as in IC7,9x.
I add a video to demonstrate the issue (comments welcome, but i think its not a user error
because it works flawlesly in IC7.
Tessellation :
75% of original size (was 670x19) - Click to enlargehttps://forum.reallusion.com/uploads/images/ea5877a8-7306-4926-a952-a971.jpg
Also put a message in the Tracker:
(removed)
Posted Last Year
Try going with 150-200 mm camera and then balance Fog Start/End with Sky scaling for the best visual.
And yes, Sky360 dome is a lot better choice due to its transform flexibility.
Just do not forget to crank the Self-Illumination all the way up for the material.
K_Digital
K_Digital
Posted Last Year
Interesting ill try that !
Matheus Carvalho
Matheus Carvalho
Posted Last Year
New Member (6 reputation)New Member (6 reputation)New Member (6 reputation)New Member (6 reputation)New Member (6 reputation)New Member (6 reputation)New Member (6 reputation)New Member (6 reputation)New Member (6 reputation)
Posts: 1, Visits: 33
Could someone please help me, as soon as I open the iclone it starts to move on its own on the x axis from left to right without stopping.
Posted Last Year
Posts: 15.8K, Visits: 31.3K
What I do instead of using the Sky element (.iSky) is to use the built-in Sky dome prop and map the sky texture on that.
You can play with the scale and depending on the setting the fog will partially hide the sky. The color of the fog also play a role. It's not perfect, but adequate in my case.
Without fog:
With fog:
K_Digital
K_Digital
Posted Last Year
Thanks for the answer, but this doesnt seem to work.
The fog covers the center of the sky dome only. So if i make the sky smaller/larger only the centered (dark) fog area changes but not the thickness of the fog,
which i would have expected to become thinner/thicker. So in all i wont be able to make the sky shine through, not even when readjusting the fog sliders .
Hope i am not understanding this feature the wrong way.
75% of original size (was 670x19) - Click to enlargehttps://forum.reallusion.com/uploads/images/26eae0d2-e2da-40aa-9477-b1aa.jpg
75% of original size (was 670x19) - Click to enlargehttps://forum.reallusion.com/uploads/images/982e9e9b-8ddd-4944-a096-48fc.jpg
Posted Last Year
using Fog on a sky "Fog influence" makes the sky completely dark
It all comes down to sky scaling. By default it's scaled to 1000 (a huge sphere which stretches beyond fog end distance).
You may set the sky scale to 100 and then go up as necessary to accommodate for distant shots and at the same time to be within the reasonable distance "inside" the fog.
K_Digital
K_Digital
Posted Last Year
Not shure where to post this, i assume the follwing still counts for IC8,4. (FB Issue  = Active)
using Fog on a sky "Fog influence" makes the sky completely dark. I would expext a slider or something that can determine
how much the fog has influence on the sky.Wonder if this is normal.
https://www.reallusion.com/FeedBackTracker/Issue/Fog-only-on-or-off-Bug
75% of original size (was 670x19) - Click to enlargehttps://forum.reallusion.com/uploads/images/ef71a9f0-fabf-4d8b-bd2b-74f9.jpg
3
4
5
6
7
