bunnywoop
bunnywoop
Posted Last Year
Visits: 23
Ok, you need a base for 4K to work, however... .. why does it insist on lowering it to 2K "for performance" Let me decide. It takes more time and steps just to go back to 4K, if I don't forget in the process.
bunnywoop
bunnywoop
Posted Last Year
Visits: 23
and why would it crash every time I try to make a 4K tex in skin tab?
bunnywoop
bunnywoop
Posted Last Year
Visits: 23
Hey, Hmmm, Well, this happens when I disable this option (use T0 as Ref Pose) when importing a cc from CC4 4.42.3004.1 It is fine with the option. Seems like I have to use it even though I don't want it. :) 21% of original size (was 2456x705) - Click to enlarge
ChengJhong(RL)
ChengJhong(RL)
Posted Last Year
Visits: 36
Do you mean zbrush not starting after facetool sent the data? Or zbrush version option not showing in the dialog when you're installing zbplugin with facetool?
Please check if the file exists: C:\Users\Public\Pixologic\GoZBrush\GoZ_Config.txt And registry: HKEY_LOCAL_MACHINE\SOFTWARE\Maxon\ZBrush 2023.2.2 for maxon HKEY_LOCAL_MACHINE\SOFTWARE\Pixologic\ZBrush 2023 for pixologic
If all the files and registries are valid, please provide screen shot so I can test with same configuration.
Posted Last Year
Posts: 23.1K,
Visits: 36.6K
Ascensi (6/3/2024) The feedback tracker takes too long for responses to bugs -often months and I cannot wait, so I'm posting here instead because people often *share* their experiences and fixes here, or site the same issue.
If any issue is urgent or seriously affecting your use of CC4, then please always feel free to contact Support using the link below. They will try to help you. https://www.reallusion.com/CustomerSupport/UserEx/QForm.html
Ascensi
Visits: 1.9K
claudius_031152
claudius_031152
Posted Last Year
Visits: 3
actually, the problem was solved with a driverupdate that was recommended, thanx to your technical support! :o)
claudius_031152
claudius_031152
Posted Last Year
Visits: 3
Hello@all! I made the hubupdate today, btw I didn't use the reallusion programs for a longer period of time now, because I'm just a hobbyist and now CC4 won't load at all! It just shows the guys face for maybe 2 seconds and then disappears again. what to do? the hub doesn't let me install a new CC4 .exe because it says it has been installed already. The older iClone (vers.7.sth) on my pc is functioning. so what to do? deinstall all and start from the beginning? Thanx a lot, Claudius from Germany
Posts: 5.3K,
Visits: 16.6K
Adjust Bones for Humanoids does not work right.
Instead of moving selected bones joint (like with CC Base Characters), the entire FK chain is getting moved. I remember it was working correctly before and looks like was invalidated with one of the updates. 21% of original size (was 2456x705) - Click to enlarge While we are at it, the symmetry selection needs to be enabled here as well. At least for the armature generated with AccuRig. FT 11236
Posted Last Year
Posts: 23.1K,
Visits: 36.6K
ronalderhodes (4/3/2024)
Processor AMD Ryzen Threadripper PRO 7995WX 96-Cores 2.50 GHz Installed RAM 128 GB (128 GB usable) System type 64-bit operating system, x64-based processor Graphics Card Nvidia RTX 4090Thanks for supplying your computer specifications. As these are clearly not the issue and you are using a high end computer, please can you contact our Technical Support department using the link below. They will work with you to get this issue resolved. Thanks.
