Poses are not loeading like in preview
Posted By K_Digital 3 Years Ago
K_Digital
K_Digital
Posts: 327, Visits: 1.4K
Hello, not shure if this is intended or not.
CC3-44 / CC4.22
I saved the default char from CC3 as iavatar to disk.
Then loaded it into CC4.
Loading that iavatar into CC4 removes the pose.
CC4 seems to remove any pose thats displayed in the thumbnail preview and replaces it with the same pose.
Then i manually exported the CC3 pose into an .imotionplus file and droped that on the CC4 char
This changed the pose to the desired CC3 one
Then i saved that char under custom chars in CC4
Reloading this into CC4 again removes the pose shown in the thumbnail
(see image)
Couldnt find a setting for that, so is this intended or may be a bug or is there a  way to
load a certain pose when loading a char without doing this manually in 2 steps ?
https://forum.reallusion.com/uploads/images/3003eab7-3b7b-468f-8a13-b2ca.jpg
michaelrbarton
michaelrbarton
Posts: 974, Visits: 11.2K
Here is a Reallusion link to set a new default pose.
God Bless.
Character Creator 4 Online Manual - Creating Custom Default Pose (reallusion.com)
K_Digital
K_Digital
nThe pose seetings are currently either bugged or just comfusing
- The "default pose" does not work when starting a new project and loading a char.
- The default pose seems to work differently when loading a custom and a factory char
- When loading a custom char (see thumbs on the left) or iavatar into a new project, the pose snaps into that position, while
    loading the factory lady with the blue skirt snaps into a pose without the knee up !
- The default pose only works when clicking on restore pose in the pose editor
- In my opinion it should be the other way around, a pose like shown in the thumbnail should be loaded into the main window
and not only be available only when clicking on "restore pose" in the pose editor
(Note: Saving the current shown pose into a  project will show up properly when reloading that project)
Big question: where does that pose come from where my char lifts her knee up a little like shown below ?
This is not the pose i have created (see thumb on the left), i must click restore pose to bring the pose shown
in the thumb into the scene.
The pose with the knee up must be defined/stored somewhere else, but where (if its not a bug) ??
https://forum.reallusion.com/uploads/images/eef9ce0a-75c3-4936-8974-ca46.jpg
https://forum.reallusion.com/uploads/images/3dfb3362-8623-4fca-a261-f33e.jpg
Posts: 5.3K, Visits: 16.8K
Poses never saved with iAvatar.
If you need to save the pose, save as ccProject (it does include pose, atmosphere, camera and all other scene attributes).
K_Digital
K_Digital
Sorry Sir, that is incorrect.
- Make New project
- load any char
- change pose , "make pose default"
- save iavatar (1) or char into custom library
- change pose to something totally different, "make new pose default"
- save another iavatar (2) or into custom library
- Make new project
- Import (1)
- goto edit pose panel and click reset to default
- Import (2)
- you will see the different poses that were stored with your iavatars
Posts: 15.8K, Visits: 31.4K
Most interesting and a bit shocking to that 4u2ges could be wrong...:unsure:
Now, to get back to your question though, I don't think I want the current behavior to change.
Often times I would apply various poses to check the character's clothing for example, and I would not want the last pose I used to be saved with the character as default.
K_Digital
K_Digital
Thanks for your kind response,
This is shurely not a big issue, i can handle it the was it is,
though i would love to find out why poses are shown
so differently when loading chars form the library like described above.
Most interesting and a bit shocking to that 4u2ges could be wrong...Unsure
:D:w00t:
I dismissed a default pose because it is a built-in "feature" and was already discussed above...
Other than that, yes, sometimes it's a bit annoying that I have to save as a project to retain a pose which will be assumed on load.
I have many of my characters submitted as project on marketplace for that reason.
