iClone 8.2 - Now Available
Posted By Susan (RL) 3 Years Ago
LarryPlane
LarryPlane
Posts: 420, Visits: 4.2K
Will 8.2 be released in from form?
mcmikexx
mcmikexx
Senior Member (465 reputation)Senior Member (465 reputation)Senior Member (465 reputation)Senior Member (465 reputation)Senior Member (465 reputation)Senior Member (465 reputation)Senior Member (465 reputation)Senior Member (465 reputation)Senior Member (465 reputation)
Last Active: 8 Months Ago
Posts: 24, Visits: 354
Thanks for the advice Joanne, that worked. and everything updated.
Joanne (RL)
Joanne (RL)
Posts: 300, Visits: 4.9K
Hi,
Could you try to execute the refresh button?
RL Hub will auto-refresh and popup the update inform when the computer starts up.
However, if there is no internet connection when the computer starts up, RL Hub will remain in original status.
In this case, manual refresh is required.
mcmikexx
mcmikexx
As I said, the Hub says everything is up to date.
Posts: 15.8K, Visits: 31.4K
In the menu on the left side click Updates. That should show the updates.
mcmikexx
mcmikexx
My Hub is not letting me upgrade to the new versions for both IC8 and CC4, it says all my products are up to date. How can I get it to let me download the new versions?
Posts: 23.1K, Visits: 36.6K
blindman (3/2/2023)
The Edit motion layer dialogue for some reason now has the purple hand and foot contact  guides activated with no way of turning them off. the relative position of the guides in relation to the hands and feet are so out of align they are useless, for reference. and don't serve any practical use for 99% of the time even if  a user wanted them visible.  by all means have the function but exercise some common sense and have the option to turn them off. When I'm placing hands on objects I need to see the mesh surfaces not purple blobs
If the guides you mention are those in the screenshot below then they can be turned off by clicking the "Viewport Controller" button highlighted in red. If these are not the issue, please post a screenshot showing what you mean. Thanks.
https://forum.reallusion.com/uploads/images/ecbd3015-b1fd-4bcb-9c51-b52c.jpg
ade.p
ade.p
Junior Member (194 reputation)Junior Member (194 reputation)Junior Member (194 reputation)Junior Member (194 reputation)Junior Member (194 reputation)Junior Member (194 reputation)Junior Member (194 reputation)Junior Member (194 reputation)Junior Member (194 reputation)
Posts: 14, Visits: 256
The new Look-At models are excellent.  The old ones were good enough that I didn't realise I needed the new ones, but 8.2's are excellent - top work, Reallusion team.
blindman
blindman
Veteran Member (948 reputation)Veteran Member (948 reputation)Veteran Member (948 reputation)Veteran Member (948 reputation)Veteran Member (948 reputation)Veteran Member (948 reputation)Veteran Member (948 reputation)Veteran Member (948 reputation)Veteran Member (948 reputation)
Posts: 57, Visits: 374
Whatever reallusion is doing the so called increase in performance for textures. Having run a series of tests a  full set of textures for a character loaded from  a material plus file is 3 to 4 seconds slower while consuming 20% more CPU usage after the 8.2 update than before,   That's more power usage for less performance !.
While the new wrinkle function can be turned on or off, But The Edit motion layer dialogue for some reason now has the purple hand and foot contact  guides activated with no way of turning them off. the relative position of the guides in relation to the hands and feet are so out of align they are useless, for reference. and don't serve any practical use for 99% of the time even if  a user wanted them visible.  by all means have the function but exercise some common sense and have the option to turn them off. When I'm placing hands on objects I need to see the mesh surfaces not purple blobs
toystorylab
toystorylab
Distinguished Member (17.3K reputation)Distinguished Member (17.3K reputation)Distinguished Member (17.3K reputation)Distinguished Member (17.3K reputation)Distinguished Member (17.3K reputation)Distinguished Member (17.3K reputation)Distinguished Member (17.3K reputation)Distinguished Member (17.3K reputation)Distinguished Member (17.3K reputation)
Posts: 4.6K, Visits: 29.9K
zeek1 (2/26/2023)
Did you do livelink through iclone or auto setup through cc4? I did it with livelink.
No livelink, exported fbx and ran auto setup in unreal...
