LarryPlane
LarryPlane
Last Active: 9 Months Ago
Visits: 4.2K
Will 8.2 be released in from form?
mcmikexx
mcmikexx
Last Active: 4 Months Ago
Visits: 353
Thanks for the advice Joanne, that worked. and everything updated.
Joanne (RL)
Joanne (RL)
Visits: 4.9K
Hi, Could you try to execute the refresh button?  RL Hub will auto-refresh and popup the update inform when the computer starts up. However, if there is no internet connection when the computer starts up, RL Hub will remain in original status. In this case, manual refresh is required.
mcmikexx
mcmikexx
Visits: 353
As I said, the Hub says everything is up to date.
Posts: 15.8K,
Visits: 31.4K
In the menu on the left side click Updates. That should show the updates.
mcmikexx
mcmikexx
Visits: 353
My Hub is not letting me upgrade to the new versions for both IC8 and CC4, it says all my products are up to date. How can I get it to let me download the new versions?
Posts: 23.1K,
Visits: 36.6K
blindman (3/2/2023) The Edit motion layer dialogue for some reason now has the purple hand and foot contact guides activated with no way of turning them off. the relative position of the guides in relation to the hands and feet are so out of align they are useless, for reference. and don't serve any practical use for 99% of the time even if a user wanted them visible. by all means have the function but exercise some common sense and have the option to turn them off. When I'm placing hands on objects I need to see the mesh surfaces not purple blobsIf the guides you mention are those in the screenshot below then they can be turned off by clicking the "Viewport Controller" button highlighted in red. If these are not the issue, please post a screenshot showing what you mean. Thanks.
ade.p
Last Active: 6 Months Ago
Visits: 256
The new Look-At models are excellent. The old ones were good enough that I didn't realise I needed the new ones, but 8.2's are excellent - top work, Reallusion team.
blindman
blindman
Last Active: 7 Months Ago
Visits: 374
Whatever reallusion is doing the so called increase in performance for textures. Having run a series of tests a full set of textures for a character loaded from a material plus file is 3 to 4 seconds slower while consuming 20% more CPU usage after the 8.2 update than before, That's more power usage for less performance !. While the new wrinkle function can be turned on or off, But The Edit motion layer dialogue for some reason now has the purple hand and foot contact guides activated with no way of turning them off. the relative position of the guides in relation to the hands and feet are so out of align they are useless, for reference. and don't serve any practical use for 99% of the time even if a user wanted them visible. by all means have the function but exercise some common sense and have the option to turn them off. When I'm placing hands on objects I need to see the mesh surfaces not purple blobs
toystorylab
toystorylab
Posts: 4.6K,
Visits: 29.9K
zeek1 (2/26/2023) Did you do livelink through iclone or auto setup through cc4? I did it with livelink.No livelink, exported fbx and ran auto setup in unreal...
