yorgon
yorgon
Visits: 316
https://www.3dscanstore.com/textures/face-texture-mapsI would like to ask a question to the Reallusion team Are there any plans for a plugin or feature that can automatically import the face maps from the 3D Scan Store page into cc4? Adding this feature to a great program like CC4 would make it a powerful tool
K_Digital
K_Digital
Visits: 1.4K
I was looking for something like that too, Cant give a precise answer yet, just purchased Headshot 2, but if you own Headshot 2, You may be able to load a different texture map in mesh mode or reproject a photo on that headmesh.
EDIT: I would try to load a texture under ->Modify->Material Tab for a test.
Posts: 15.8K,
Visits: 31.4K
3Dscan terms and conditions for any license state that the following is not allowed: - Integration of our scan data into any character maker programme whereby the results can be exported as 3d models in any 3d format. Including but not limited to Daz 3D, Reallusion character creator.
So that makes it pretty much useless for our purposes.
jeff.davies
jeff.davies
Visits: 1.5K
Interesting. If they don't allow you to use the scans for characterr creation software, what is the point of these scans? Just fior static renders?
- Jeff The Adventures of Capt Sanchez Cybernautic Studios
Sp3c1alk
Sp3c1alk
Posted Last Year
Last Active: 10 Months Ago
Visits: 498
You can load a scan into headshot 2. It takes a little work, but you can get it almost spot on. Then the textures transfer automatically. Once you edit the head, you can export the textures and fix them.
Djeisoncanuto
Djeisoncanuto
Posted Last Year
Last Active: 5 Months Ago
Visits: 186
i do this quite often now. It's pretty good except I can't get it to transfer all textures. Just normal and albedo. No roughness or specular maps. Any luck with that?
In the meantime, I have been using Facefrom Wrap to transfer all my textures to the iclone basemesh. Swapping them out from there is pretty "easy" from there
Djeisoncanuto
Djeisoncanuto
Posted Last Year
Visits: 186
Here is a test I just did. Needs som texture clean up but it works well.
