CC4-3D Scan
https://forum.reallusion.com/Topic532022.aspx
Print Topic | Close Window
By yorgon - 3 Years Ago
https://www.3dscanstore.com/textures/face-texture-maps
I would like to ask a question to the Reallusion team
Are there any plans for a plugin or feature that can automatically import the face maps from the 3D Scan Store page into cc4?
Adding this feature to a great program like CC4 would make it a powerful tool
By K_Digital - 3 Years Ago
I was looking for something like that too, Cant give a precise answer yet, just purchased Headshot 2, but if you own Headshot 2, You may be able to load a different texture map in mesh mode or reproject a photo on that headmesh.
EDIT: I would try to load a texture under ->Modify->Material Tab for a test.
By animagic - 3 Years Ago
3Dscan terms and conditions for any license state that the following is not allowed:
- Integration of our scan data into any character maker programme whereby the results can be exported as 3d models in any 3d format. Including but not limited to Daz 3D, Reallusion character creator.
So that makes it pretty much useless for our purposes.
By jeff.davies - 3 Years Ago
Interesting. If they don't allow you to use the scans for characterr creation software, what is the point of these scans? Just fior static renders?
By Sp3c1alk - 2 Years Ago
You can load a scan into headshot 2. It takes a little work, but you can get it almost spot on. Then the textures transfer automatically.  Once you edit the head, you can export the textures and fix them.
By Djeisoncanuto - 2 Years Ago
i do this quite often now. It's pretty good except I can't get it to transfer all textures. Just normal and albedo. No roughness or specular maps. Any luck with that?
In the meantime, I have been using Facefrom Wrap to transfer all my textures to the iclone basemesh. Swapping them out from there is pretty "easy" from there
