Iclone 4 AP has stopped working
Posted By DGM357 14 Years Ago
DGM357
DGM357
Posted 14 Years Ago
Veteran Member (652 reputation)Veteran Member (652 reputation)Veteran Member (652 reputation)Veteran Member (652 reputation)Veteran Member (652 reputation)Veteran Member (652 reputation)Veteran Member (652 reputation)Veteran Member (652 reputation)Veteran Member (652 reputation)
Last Active: 14 Years Ago
Posts: 3, Visits: 36
I've been using iclone for a while, and now when i click any of the taps, it closes the program with this error message.
What does AP stand for?
Why does iclone not want to work?
DesertWalker
DesertWalker
Posted 14 Years Ago
Distinguished Member (3.3K reputation)Distinguished Member (3.3K reputation)Distinguished Member (3.3K reputation)Distinguished Member (3.3K reputation)Distinguished Member (3.3K reputation)Distinguished Member (3.3K reputation)Distinguished Member (3.3K reputation)Distinguished Member (3.3K reputation)Distinguished Member (3.3K reputation)
Last Active: 7 Years Ago
Posts: 365, Visits: 508
I once had this problem when I used iClone on an old pc. Is yours old, too. If yes, I can share a tip or two on how to manage.
bobkat2000
bobkat2000
Posted 14 Years Ago
Last Active: 9 Years Ago
Posts: 60, Visits: 235
The "Iclone AP has stopped working" error is some sort of problem within Iclone.  I have had it happen on 32 bit Vista, 32 bit XP, 64 bit Vista Ultimate, 64 bit XP pro and in Windows 7.
It happens at least 5-10 times per day minimum and the only solution is to restart Iclone and hope it doesn't happen before you save your work.....which has caused me to constantly save my work....like every 30-60 seconds or so.
Posted 14 Years Ago
Distinguished Member (122.0K reputation)Distinguished Member (122.0K reputation)Distinguished Member (122.0K reputation)Distinguished Member (122.0K reputation)Distinguished Member (122.0K reputation)Distinguished Member (122.0K reputation)Distinguished Member (122.0K reputation)Distinguished Member (122.0K reputation)Distinguished Member (122.0K reputation)
Last Active: Today @ 12:48 AM
Posts: 23.0K, Visits: 36.3K
It is almost impossible to give an exact answer without knowing your full system specifications.
Please use the link below to submit your problem to Technical Support and they will attempt to help you resolve these issues.
http://www.reallusion.com/CustomerSupport/User/QForm.aspx
Thanks.
bobkat2000
bobkat2000
Posted 14 Years Ago
Boxx 8520 Series (www.boxxtech.com)
Operating System
Microsoft Windows 7 Professional Edition 64-Bit
CPU
WS DUAL XEON X5570 2.93GHz, 8MB cache, 1333 MHz
Memory
6GB DDR3-1333 REG ECC (6 - 1GB DIMMS) (R)
Video Cards
NVIDIA Quadro FX 3800 1GB PCI-E (R)
Hard Drives
4 - 500GB 7,200rpm SATA (SUB)
Posted 14 Years Ago
The professional workstation setup you have there is certainly powerful enough but does fall outside the normal setup used by the average iClone user. I think you would be best to contact Technical Support using the link I posed above. They should be able to advise you of some things to try to help resolve the problems you are having.
Thanks.
jimmygee
jimmygee
Posted 14 Years Ago
Posts: 219, Visits: 1.6K
I too have this problem.I thought it was just me,or my computer(which I was considering changing)
The problem was evident with iClone 3.2, so I upgraded to iClone 4.2,but the problem still persists.At the moment, if I'm working on a project for more than 5 mins,I save it before it closes on me.I did contact Reallusion Support,their suggestion of disabling Windows Firewall and upgrading my Graphics Card,made no difference. I have installed Reg Cleaner,Windows Security,Windows Updates,running iClone as Administrator etc but still it happens.
I would appreciate if this problem can be resolved, and some kind person can post the solution here. Smile
Jimmy
Posted 14 Years Ago
jimmygee (6/16/2010)
Jimmy
Hi Jimmy,
Have you contacted Support again with this problem?
If not it would be worth while as they may be able to offer you further advice and help with this issue. As always please use the link below to request assistance.
http://www.reallusion.com/CustomerSupport/User/QForm.aspx.
jimmygee
jimmygee
Posted 14 Years Ago
After contacting Reallusion Support,they asked for DXdiag in text and file format.Two days later they said that as far as they could tell, there was nothing wrong with my system or the iClone software.They also said they had not come across this problem before.
Trying to get to the root of the problem,I decided to start from scratch.
I will pass on what I did,because for the last two weeks,the problem has never occurred again.
I'm not sure if this will resolve everyone else's problems.But so far it's working for me.
First,I uninstalled iClone.
I may have had some conflicting software,so I removed and uninstalled old programmes, or programmes that I did not use,or were downloaded from "Free Sites".
I defragmented hard drive,system clean up and system restore.
I also uninstalled AVG Anti-Virus and now use only Windows Security Essentials and Firewall.
I then reinstalled iClone.
Repeating what I said earlier,so far (two weeks) no problems,no shutting down suddenly,no blue screen,no freezing or slowing down.
I had tried everything else, but this simple solution has resolved my issue.
Jimmy
Posted 14 Years Ago
Hi Jimmy,
Thanks for updating on your experience. Glad to hear you were able to resolve the issue successfully. Smile
