Ver 2.0 Affinity Apps no longer work on Windows
Posted By AverageJoe 2 Years Ago
AverageJoe
AverageJoe
Distinguished Member (11.4K reputation)Distinguished Member (11.4K reputation)Distinguished Member (11.4K reputation)Distinguished Member (11.4K reputation)Distinguished Member (11.4K reputation)Distinguished Member (11.4K reputation)Distinguished Member (11.4K reputation)Distinguished Member (11.4K reputation)Distinguished Member (11.4K reputation)
Last Active: 10 Months Ago
Posts: 2.4K, Visits: 10.1K
It's a sad day... Affinity Photo and Designer ver 2.0 was released, and unfortunately will no longer work with CTA5 (nor 4 I would assume).  The new version of Affinity applications install into C:\Program Files\WindowsApp which Microsoft, for whatever reason has made it inaccessible.  Tis true, Microsoft has hidden away folders and files on your very own system, and you cannot access them without some kind of registry hack.  Supposedly there are alias files for these hidden locations, but unfortunately, CTA5 will not accept them.
So, if you're an Affinity user and use Photo or Designer in CTA5, either hold off on upgrading to version 2.0, or don't replace your older Affinity apps when installing the new ones.
Either way, I'm really kinda miffed about it.
Threaded View
Threaded View
Forum Post Ver 2.0 Affinity Apps no longer work on Windows By AverageJoe ( 2 Years Ago )
Forum Post There is no need for any "registry hacks" to view hidden folders. In... By wires ( 2 Years Ago )
Forum Post That will not work for C:\Program Files\WindowsApps. By AverageJoe ( 2 Years Ago )
Forum Post This issue also occurred with Affinity Ver 1.0 products if you... By Peter (RL) ( 2 Years Ago )
Forum Post I bought them directly from Serif, through an upgrade offer.... By AverageJoe ( 2 Years Ago )
Forum Post Do make sure to restart your computer for the new permission settings... By Peter (RL) ( 2 Years Ago )
Forum Post Still a no-go. I uninstalled the Affinity apps, re-installed. made... By AverageJoe ( 2 Years Ago )
Forum Post Are you able to launch Affinity Designer/Photo 2 from within the... By Peter (RL) ( 2 Years Ago )
Forum Post I hadn't thought of trying that since the Desktop shortcut links... By AverageJoe ( 2 Years Ago )
Forum Post I'm having the exact same issue on my PC (Windows 10 Professional). I... By EmpTur ( 2 Years Ago )
Forum Post Has anyone from Reallusion looked into this further? By AverageJoe ( 2 Years Ago )
Forum Post [quote][b]AverageJoe (11/12/2022)[/b][hr]Has anyone from Reallusion... By wires ( 2 Years Ago )
Forum Post Because it's entirely possible that Reallusion could discover a... By AverageJoe ( 2 Years Ago )
Forum Post [quote][b]AverageJoe (11/12/2022)[/b][hr]Because it's entirely... By Peter (RL) ( 2 Years Ago )
Forum Post Thanks Peter. rosuckmedia's solution did the trick, and was a lot... By AverageJoe ( 2 Years Ago )
Forum Post You can achieve this b y replacing default.svg in the source... By danielpojda ( 2 Years Ago )
Forum Post Thanks danielpojda... Your steps outlined here are what I surmised,... By AverageJoe ( 2 Years Ago )
Forum Post Sorry, I thought I was in the German forum. Hello, I don't think that... By Jünni ( 2 Years Ago )
Forum Post Hello Günter are you using Affinty Phote 2.0? I assume you have... By rosuckmedia ( 2 Years Ago )
Forum Post Hello Robert, Yes, I have Vers. 2.0 and do not have MSIXinstalled but... By Jünni ( 2 Years Ago )
Forum Post Sorry, the browser went crazy with my last post. The text is at the... By Jünni ( 2 Years Ago )
Forum Post I am hoping that Affinity fixes this, but to avoid wasting money and... By grinnbear ( 2 Years Ago )
Forum Post @AverageJoe Hello, I have downloaded a trial version of Affinity... By rosuckmedia ( 2 Years Ago )
Forum Post Thanks Robert, I did as you suggested. And it works... sorta... When... By AverageJoe ( 2 Years Ago )
Forum Post @rosuckmedia Thank you for the information. I did wonder why I could... By rogdodge ( 2 Years Ago )
Forum Post Hi - I'd like to try this but am unsure of the following step in the... By Jowin ( 2 Years Ago )
Forum Post I worked out the the message from 'danielpojda' and made a... By robot-49 ( 2 Years Ago )
Forum Post Looks as though Serif have seen the light and intend to make a... By wires ( 2 Years Ago )
