Iclone 8 "Failed to Load File" continues to be an issue
Posted By Cary B 3 Years Ago
Cary B
Cary B
Posts: 478, Visits: 3.8K
Others have shared that they are experiencing the same issue that I am experiencing. I will be working on a project, and it will work fine with no apparent issues, no kind of lag or such.  I stop and save the project. When I come back to start it up, the file starts to load normally, but just before completing, it stops and up pops the message "Failed to load file".
This has happened repeatedly, with smaller project files as well as larger ones. It is difficult to figure out a common thread. I updated my Nvidia drivers, and I thought that helped, but then the issue started cropping up again.
At one point I thought that the problem was possibly associated with using some old legacy animations, but even after I stopped using them, I continue to get the problem (though less often)
It is extremely annoying to lose this work over and over. I have tried to compensate by only doing very brief projects with just a few seconds of animation, rendering that, then saving a version of the project with all the animation removed. But it's a pain in the neck, and piles up all these extra project files.
I do think there is some issue with the way Iclone 8 saves animations that may be causing this "Failed to load file" issue.   The difference in size between project files saved with animations and the same one saved without animation is often much, much greater.
https://forum.reallusion.com/uploads/images/848c8492-ac67-42c2-9d27-461e.jpg
Threaded View
Threaded View
Forum Post Iclone 8 "Failed to Load File" continues to be an issue By Cary B ( 3 Years Ago )
Forum Post Hi, Cary B I am so sorry to hear this, can you provide me one of your... By luke (RL) ( 3 Years Ago )
Forum Post Hey Luke, thanks for the response. I'm happy to send a file. Where... By Cary B ( 3 Years Ago )
Forum Post Hi, Cary B You can use the private message to send me the file link,... By luke (RL) ( 3 Years Ago )
Forum Post Luke, I haven't heard from you, but I am assuming that the file I sent... By Cary B ( 3 Years Ago )
Forum Post More experimenting has shown that some avatars that have been created... By Cary B ( 3 Years Ago )
Forum Post Further experiments show this apparently does not happen with the CC... By Cary B ( 3 Years Ago )
Forum Post That would happen to any characters which have at least one accessory... By 4u2ges ( 3 Years Ago )
Forum Post Thanks for the info on the ticket about the accessories. It certainly... By Cary B ( 3 Years Ago )
Forum Post I am having the same problem. I have lost a lot of work over the last... By AidemIndi ( 3 Years Ago )
Forum Post As I mentioned above, Accessories are a problem. There is no solution... By 4u2ges ( 3 Years Ago )
Forum Post [quote][b]4u2ges (8/21/2022)[/b][hr]As I mentioned above, Accessories... By AidemIndi ( 3 Years Ago )
Forum Post [quote][b]AidemIndi (8/21/2022) Unfortunately, my characters do not... By Cary B ( 3 Years Ago )
Forum Post Hi Cary B, Thanks for the heads up on the beard. But I've noticed the... By AidemIndi ( 3 Years Ago )
Forum Post Appreciate so much the step-by-step workaround, 4u2ges. This will help... By Cary B ( 3 Years Ago )
Forum Post Hi Cary B, I'm in the same boat as you and really hacked off with... By AidemIndi ( 3 Years Ago )
Forum Post Pretty sure it's not related to licenses, Aidemlndi. The avatars... By Cary B ( 3 Years Ago )
Forum Post For some distant characters you may save further by using a 2D on... By 4u2ges ( 3 Years Ago )
Forum Post Did some quick testing. Took an avatar with attached accessory into... By Cary B ( 3 Years Ago )
Forum Post Hi, Cary B Thank you for the information, it helps us a lot. Here is... By luke (RL) ( 3 Years Ago )
Forum Post [quote][b]luke (RL) (8/22/2022)[/b][hr]Hi, Cary B Thank you for the... By AidemIndi ( 3 Years Ago )
Forum Post Hi, Aidemlndi I saw your ticket, will reply to you asap, thanks Luke... By luke (RL) ( 3 Years Ago )
Forum Post I installed building block plugin and when I try to build it keeps... By yabrahaim ( 2 Years Ago )
Forum Post Hi, I'm fairly new to the software and have run into the "failed to... By storiedknowledgechannel ( Last Year )
Forum Post [quote][b]storiedknowledgechannel (1/7/2024)[/b][hr]Hi, I'm fairly new... By Peter (RL) ( Last Year )
Forum Post Hi Peter, I don't see an update available for IClone in the Reallusion... By storiedknowledgechannel ( Last Year )
Forum Post Never mind on my last post, I uninstalled and the new version showed... By storiedknowledgechannel ( Last Year )
Forum Post I have the same issue with 8.4 . I've been waiting for days for a... By raywatson0992 ( Last Year )
Forum Post [quote][b]raywatson0992 (5/4/2024)[/b][hr]I have the same issue with... By Peter (RL) ( Last Year )
