FBX Character Imported Has Washed Out/Faded Textures
Posted By arrrtie 3 Years Ago
arrrtie
arrrtie
Junior Member (224 reputation)Junior Member (224 reputation)Junior Member (224 reputation)Junior Member (224 reputation)Junior Member (224 reputation)Junior Member (224 reputation)Junior Member (224 reputation)Junior Member (224 reputation)Junior Member (224 reputation)
Posts: 15, Visits: 151
Hello!
I'm a new user to CC4, and I've brought in several Daz characters through the transformer tool, which has more or less been good enough. Today I tried to import an FBX file for a character with the 'Create Character' option, but while I was adding textures, the character looks extremely pale and washed out. I've been experimenting with it for a few hours with no usable results. When I upload the FBX to Blender and add textures, it looks as it is supposed to, so I must be doing something wrong in CC4. The only difference between this and the Daz characters I used in the past is the method of importing, using Transformer didn't require me to add textures manually, and it isn't an option for this character. Thanks for the help!
*Note, the eyelashes are untextured because I think I'm missing a file from the original purchase.
https://forum.reallusion.com/uploads/images/6b8c0828-1025-48d9-b2e1-cd1d.jpg
https://forum.reallusion.com/uploads/images/5d6e9bfa-6cc7-47f1-8145-2519.jpg
Hobbyist Animator//Jack Skellington Enthusiast
CPU: 3950x | GPU: RTX 3090 | RAM: 64 Gb
playlogic
playlogic
Senior Member (439 reputation)Senior Member (439 reputation)Senior Member (439 reputation)Senior Member (439 reputation)Senior Member (439 reputation)Senior Member (439 reputation)Senior Member (439 reputation)Senior Member (439 reputation)Senior Member (439 reputation)
Posts: 45, Visits: 211
Hey,
It going to be a little hard to help you diagnose the problem without actual access to the characters and also without seeing your lighting setup.
You will find that a lot of CC characters you see have several Post Effects in the Visual tab added to achieve the viewport renders they show off.
See if adding a Color Adjust, or  (LUT) Contrast into the visual tab to see if you start to get the results you are looking for.
Update: Here a export Contrast Effect
https://forum.reallusion.com/uploads/images/1bdc8c75-509e-4181-9dc3-3efd.jpg
Posts: 8.2K, Visits: 62.5K
I think your rendering method may be set to "Minimal" Try setting it to "High".
Also check the strength slider for the texture. It may be set to 80% instead of 100%. Slider is just under the texture thumbnails.
arrrtie
arrrtie
Thanks for the responses! I'll look at both of these options, but I realized that this character doesn't have a facial rig that can be used in iClone, so I abandoned as a lost cause. Thanks for your help!
playlogic
playlogic
Hi,
Just adding this for answer just in case someone else ask/search about this issue;
Another place to check is the both the "Use sRGB" and "Strength" in the texture panel.
Using the strength slider, you can adjust the overall strength of the texture.
*UPDATE* Realized after posting that @Rampa had already mentioned this...including a helpful tip about checking the render level
https://forum.reallusion.com/uploads/images/c9fc4940-2911-4379-9196-117c.gif
