How to reproduce:
- create an IC8 project
- add a Point Light
- change some of its parameters
- turn ON Volumetric Light and Unlink Light Intensity
- modify the Intensity parameter from default 2.0 to any other value
- apply "Remove object animation"
- all light's parameters are properly kept, with the exception of Intensity, which resets to its default value 2.0
Workaround
- copy the keyframe before applying the "Remove Object Animation" then paste it at frame 0.
FeedbackTracker:
https://www.reallusion.com/FeedBackTracker/Issue/Remove-Object-Animation-does-not-preserve-light-s-volumetric-intensity
______________________________________________________________________________
Software developer. iClone hobbyist since January 11, 2020. Best work so far: Robots among us: The Lab and The sad end of a legend
In progress: Black Mamba
AMD Ryzen 3950X 16C/32T 4.2 GHz, 64GB RAM, RTX2080 11GB, 2TB Samsung 970 Pro SSD, 8TB Seagate BarraCuda HDD, Win11 64-bit, iClone 8.12
