I Finally Produced The Look and Photorealism I've Been Trying For.
Posted By harris.josephd 4 Years Ago
harris.josephd
harris.josephd
Posts: 252, Visits: 810
I was simply never able to do this right with the previous hardware and software.
Technically, I completely redid Riva's skin and makeup again to properly take advantage of the new machine and software.  I started with the Base Camilla Skin used the new skin tone features in CC4 and exported.  The base map was modified in GIMP. Then, I replaced several Bump maps to get everything I wanted and worked on it some more in Skin Gen. Her sub-surface scattering needed to be tweaked as well. Everything is in 4k resolution.
The new facial rigging allows for much more realistic expressions.
I used light studio and the Iray extension to get the lighting just as you see it here.
All told, these shots required nearly 8 gigs of VRAM - and this is with a card that is specifically designed to do ray tracing.
Please let me show you...  Thank you for looking.
https://forum.reallusion.com/uploads/images/7a450d35-1a9e-4a51-a82c-f274.png
https://forum.reallusion.com/uploads/images/f0d9a1d0-c406-4bf9-bb4b-e258.png
https://forum.reallusion.com/uploads/images/063c47a3-96f7-4240-adc7-1738.png
https://forum.reallusion.com/uploads/images/106b7776-6867-4944-b637-4ca1.png
Threaded View
Threaded View
Forum Post I Finally Produced The Look and Photorealism I've Been Trying For. By harris.josephd ( 4 Years Ago )
Forum Post The renders are gorgeous. You said you have an RTX card. Which one?... By lightbearer ( 4 Years Ago )
Forum Post [quote][b]lightbearer (5/27/2022)[/b][hr]The renders are gorgeous. You... By harris.josephd ( 4 Years Ago )
Forum Post Here's a WIP By harris.josephd ( 4 Years Ago )
Forum Post Overall it looks very good, possibly a little too perfect on the skin.... By jeff.davies ( 4 Years Ago )
Forum Post [quote][b]jeff.davies (5/27/2022)[/b][hr]Overall it looks very good,... By harris.josephd ( 4 Years Ago )
Forum Post so i'll respond just for you Harris :) your work has greatly... By planetstardragon ( 4 Years Ago )
Forum Post [quote]Then there's the aspect of matching the current trend of... By AutoDidact ( 4 Years Ago )
Forum Post both of them are artistic but are not mutually the same genre. The... By planetstardragon ( 4 Years Ago )
Forum Post Guys, My stated aim at the very beginning was to improve technical... By harris.josephd ( 4 Years Ago )
Forum Post [quote][b]harris.josephd (5/29/2022)[/b][hr] The art is better with... By planetstardragon ( 4 Years Ago )
Forum Post [quote][b]planetstardragon (5/29/2022)[/b][hr][quote][b]harris.josephd... By harris.josephd ( 4 Years Ago )
Forum Post [quote]AutoDidact nailed the realism with his render, it looks... By AutoDidact ( 4 Years Ago )
Forum Post There does come a point where people need to put up or shut up. This... By harris.josephd ( 4 Years Ago )
Forum Post And just to be clear on that point... This is from my most recent... By harris.josephd ( 4 Years Ago )
Forum Post [quote]There does come a point where people need to put up or shut... By AutoDidact ( 4 Years Ago )
Forum Post A few more my older original outfits. I am content creator with no... By AutoDidact ( 4 Years Ago )
Forum Post Auto... And given those shots of your work that you posted... Do you... By harris.josephd ( 4 Years Ago )
Forum Post “photorealistic”?? ..Absolutely not ( Not my goal anyway,I... By AutoDidact ( 4 Years Ago )
Forum Post AutoDidact, I am not certain if you are masochistic or delusional... By harris.josephd ( 4 Years Ago )
Forum Post Joseph, I see you are upset and angrily lashing out ,so I will... By AutoDidact ( 4 Years Ago )
Forum Post The reason I made my comments on separating the 2 ideas of technical... By planetstardragon ( 4 Years Ago )
Forum Post [quote][b]planetstardragon (5/29/2022)[/b][hr]The reason I made my... By harris.josephd ( 4 Years Ago )
Forum Post AutoDidact "Joseph, I see you are upset and angrily lashing out ,so... By harris.josephd ( 4 Years Ago )
Forum Post @planetstar , Well said. Your advice is particularly important... By AutoDidact ( 4 Years Ago )
Forum Post [quote][b]AutoDidact (5/29/2022)[/b][hr] @planetstar , Well said.... By harris.josephd ( 4 Years Ago )
Forum Post Hi Joseph, I really do like your renders. I also like that you told... By TonyDPrime ( 4 Years Ago )
Forum Post [quote][b]TonyDPrime (5/29/2022)[/b][hr]Hi Joseph, I really do like... By harris.josephd ( 4 Years Ago )
Forum Post [quote][b]harris.josephd (5/29/2022)[/b][hr][quote][b]TonyDPrime... By TonyDPrime ( 4 Years Ago )
Forum Post Tony, Thanks. I will check out unreal and or unity at some point - I... By harris.josephd ( 4 Years Ago )
Forum Post Looks great. By Jeffster The Mighty ( 4 Years Ago )
Forum Post [quote][b]Jeffster The Mighty (5/29/2022)[/b][hr]Looks great.[/quote]... By harris.josephd ( 4 Years Ago )
Forum Post Everyone's taste is different. I think you both are doing a good job... By yepkoo ( 4 Years Ago )
Forum Post [quote][b]yepkoo (5/30/2022)[/b][hr]Everyone's taste is different. I... By harris.josephd ( 4 Years Ago )
Forum Post It may not have even taken 5 minutes. The difference between us is... By yepkoo ( 4 Years Ago )
Forum Post [quote][b]yepkoo (5/30/2022)[/b][hr]It may not have even taken 5... By harris.josephd ( 4 Years Ago )
Forum Post You are right, it takes a lot of effort to gain experience on this... By yepkoo ( 4 Years Ago )
Forum Post [quote][b]yepkoo (5/30/2022)[/b][hr]You are right, it takes a lot of... By harris.josephd ( 4 Years Ago )
Forum Post You're right, I'm using Unreal Engine and still have a lot to... By yepkoo ( 4 Years Ago )
Forum Post [quote][b]yepkoo (5/30/2022)[/b][hr] You're right, I'm using Unreal... By harris.josephd ( 4 Years Ago )
Forum Post I tried this. Strange characters appear :D For example, I can... By yepkoo ( 4 Years Ago )
Forum Post [quote]1) BLENDER - Everyone has their own way of communicating.... By AutoDidact ( 4 Years Ago )
Forum Post [quote][b]yepkoo (5/30/2022)[/b][hr]I tried this. Strange characters... By harris.josephd ( 4 Years Ago )
