iClone 8.0 Official Issues Thread
Posted By Peter (RL) 3 Years Ago
3
4
5
OB1Flow
OB1Flow
Senior Member (351 reputation)Senior Member (351 reputation)Senior Member (351 reputation)Senior Member (351 reputation)Senior Member (351 reputation)Senior Member (351 reputation)Senior Member (351 reputation)Senior Member (351 reputation)Senior Member (351 reputation)
Posts: 44, Visits: 220
younggunmotion (5/18/2022)
Having the exact same issue. Motion Puppet, Direct Puppet, Edit Motion Layer, IK all not working... When I press spacebar to preview, nothing happens and sometimes IC8 just crashes on me altogether.
OB1Flow (5/12/2022)
IK Mode does not work in iClone or CC4 with any character.
FK mode will work and allow you to rotate bones but there's no limit, you can rotate full 360+ degrees on body parts.  I have tried uninstalling and re-installing as well as rebooting between those steps.
https://www.youtube.com/watch?v=q_jV3L8LMG8&ab_channel=LowBarGaming
https://www.reallusion.com/FeedBackTracker/Issue/IK-Mode-does-nothing-in-iClone8-and-CC4
System: Windows 10, Threadripper Pro 3975, 128GB Ram, dual 3090s.
Edit: Better video showing the IK panel: https://www.youtube.com/watch?v=8EhpFAgR60g&ab_channel=LowBar
Do you have a threadripper CPU by chance?
younggunmotion
younggunmotion
Junior Member (100 reputation)Junior Member (100 reputation)Junior Member (100 reputation)Junior Member (100 reputation)Junior Member (100 reputation)Junior Member (100 reputation)Junior Member (100 reputation)Junior Member (100 reputation)Junior Member (100 reputation)
Posts: 11, Visits: 313
Yup.
AMD Ryzen Threadripper 3970X 32-Core Processor  3.70 GHz
Geforce RTX 3090 (Latest Nvidia Studio Driver)
OB1Flow
OB1Flow
Looks like that's the culprit.  Glad they narrowed it down :)
Leowald
Leowald
Posts: 83, Visits: 2.9K
I have a problem with Motion Director.
I can't use it for "giants characters" for a fantasy project sadly.
More the body scale is taller, less it's working. Hope it can be fixed! I made a ticket here : https://www.reallusion.com/FeedBackTracker/Issue/Motion-Director-not-working-correctly-when-body-scale-is-bigger-than-150
jeffkirkland
jeffkirkland
Posts: 290, Visits: 1.7K
This probably isn't an earth shattering issue but if you drag and drop a project into IC8 from the File Explorer that's something other than a 16:9 - in my case they're 2K Scope - it messes up the aspect ratio. Everything gets stretched tall and thin. Works fine in IC7 as does opening the project in IC8 using the file menu.
Dragging and dropping a project from file explorer results in incorrect aspect ratio in viewer. - Feedback Tracker (reallusion.com)
Jeff Kirkland | Director • Cinematographer • Storyteller
Hobart • Tasmania • www.one18films.com
SYSTEM: AMD Ryzen 5 5500 | 32gb RAM | RTX 3060 12gb | 1tb SSD System | 44tb HDD Storage
luke (RL)
luke (RL)
Group: Power Developer
Posts: 289, Visits: 5.6K
Leowald (5/19/2022)
I am okay with that, can you provide your character to let us test?
Leowald
Leowald
luke (RL) (5/20/2022)
Leowald (5/19/2022)
Hello Luke,
I tried with many characters and it's the same problem. So you can directly test with CC4 Camila or Kevin.
Edward (RL)
Edward (RL)
Posts: 301, Visits: 4.9K
Hi,
You may find the installer exe file under:
C:\Users\<USER NAME>\AppData\Local\Reallusion\RLDownloads\
Try to install it in the traditional way to see whether works or if any error message appears.
If you cannot figure it out, you need to contact support and provide the RL hub log file, under:
C:\Users\<USER NAME>\AppData\Local\Reallusion\RLLauncher.log
luke (RL)
luke (RL)
Leowald (5/20/2022)
Leowald (5/19/2022)
Hello Luke,
Okay, here is the short video shows you how to adjust it.
LarryPlane
LarryPlane
Posts: 420, Visits: 4.2K
I'm working with iC8 trial and things seem okayish, with the odd crash, but I have seen the interface going unresponsive when i launch Face Realtime.
There also seems to be no consistency with tracking.
Overall, the web cam version of tracking does not seem to integrate with iC8, and does not seem to be something that users use. I guess everyone are using the iPhone version.
Conclusion, currently faceware rt is not stable or usable with ic8.
3
4
5
