ian_11
ian_11
Visits: 2.0K
LarryPlane (5/24/2022)
Overall, the webcam version of tracking does not seem to integrate with iC8, and does not seem to be something that users use. I guess everyone are using the iPhone version.
Conclusion, currently faceware rt is not stable or usable with ic8.
Not true I use a webcam so I need this to work iPhone is not the best selling phone :)
LarryPlane
LarryPlane
Last Active: 9 Months Ago
Visits: 4.2K
I'm working with iC8 trial and things seem okayish, with the odd crash, but I have seen the interface going unresponsive when i launch Face Realtime.
There also seems to be no consistency with tracking.
Overall, the web cam version of tracking does not seem to integrate with iC8, and does not seem to be something that users use. I guess everyone are using the iPhone version.
luke (RL)
luke (RL)
Group: Power Developer
Visits: 5.6K
Leowald (5/20/2022)
luke (RL) (5/20/2022)
I am okay with that, can you provide your character to let us test? Hello Luke, I tried with many characters and it's the same problem. So you can directly test with CC4 Camila or Kevin. Okay, here is the short video shows you how to adjust it.
Edward (RL)
Edward (RL)
Visits: 4.9K
Hi, You may find the installer exe file under: C:\Users\ <USER NAME>\AppData\Local\Reallusion\RLDownloads\ Try to install it in the traditional way to see whether works or if any error message appears. If you cannot figure it out, you need to contact support and provide the RL hub log file, under: C:\Users\<USER NAME>\AppData\Local\Reallusion\RLLauncher.log kenneth.bernardo2 (5/16/2022)
Leowald
Leowald
Visits: 2.9K
luke (RL)
luke (RL)
Visits: 5.6K
jeffkirkland
jeffkirkland
Last Active: 8 Months Ago
Visits: 1.7K
This probably isn't an earth shattering issue but if you drag and drop a project into IC8 from the File Explorer that's something other than a 16:9 - in my case they're 2K Scope - it messes up the aspect ratio. Everything gets stretched tall and thin. Works fine in IC7 as does opening the project in IC8 using the file menu. Dragging and dropping a project from file explorer results in incorrect aspect ratio in viewer. - Feedback Tracker (reallusion.com)
Jeff Kirkland | Director • Cinematographer • Storyteller Hobart • Tasmania • www.one18films.com SYSTEM: AMD Ryzen 5 5500 | 32gb RAM | RTX 3060 12gb | 1tb SSD System | 44tb HDD Storage
Leowald
Leowald
Visits: 2.9K
I have a problem with Motion Director. I can't use it for "giants characters" for a fantasy project sadly. More the body scale is taller, less it's working. Hope it can be fixed! I made a ticket here : https://www.reallusion.com/FeedBackTracker/Issue/Motion-Director-not-working-correctly-when-body-scale-is-bigger-than-150
OB1Flow
OB1Flow
Visits: 222
Looks like that's the culprit. Glad they narrowed it down :)
younggunmotion
younggunmotion
Visits: 369
Yup. AMD Ryzen Threadripper 3970X 32-Core Processor 3.70 GHz Geforce RTX 3090 (Latest Nvidia Studio Driver)
