Is it possible to export smoothed version of the Daz Character from CC3 to Unity
Posted By hvet71 4 Years Ago
Is it possible to export smoothed version of the Daz Character from...
hvet71
hvet71
Junior Member (146 reputation)Junior Member (146 reputation)Junior Member (146 reputation)Junior Member (146 reputation)Junior Member (146 reputation)Junior Member (146 reputation)Junior Member (146 reputation)Junior Member (146 reputation)Junior Member (146 reputation)
Posts: 4, Visits: 33
Hi all,
Is it possible to export a smoothed version of the Daz character from CC 3 to Unity ? I've noticed it remains low poly when I import it into the game engine.
Thanks
vadim+2
vadim+2
Veteran Member (554 reputation)Veteran Member (554 reputation)Veteran Member (554 reputation)Veteran Member (554 reputation)Veteran Member (554 reputation)Veteran Member (554 reputation)Veteran Member (554 reputation)Veteran Member (554 reputation)Veteran Member (554 reputation)
Posts: 60, Visits: 1.5K
hvet71 (4/18/2022)
Hi all,
Thanks
Not an easy task. The workaround we found on this forum is to use Maya 2020 (newer does not work properly in that regard).
Import your character to Maya
Click on the mesh so the mesh grid is visible
Click on Mesh > Smooth
After it completes smoothing you'll see that the 3d grid on mesh became denser.
Now click Edit > Delete By Type > Non-Deformer History
It can take a while for this step (depending on your hardware), but after it finishes, export your mesh as fbx.
Back up your low poly mesh and replace it with a smoothed one.
______________________________________________________________
Vadim Karpenko, Unreal Engine 4 developer.
hvet71
hvet71
Thanks Vadim :)
User1278365123
User1278365123
New Member (73 reputation)New Member (73 reputation)New Member (73 reputation)New Member (73 reputation)New Member (73 reputation)New Member (73 reputation)New Member (73 reputation)New Member (73 reputation)New Member (73 reputation)
Posts: 4, Visits: 29
"The workaround we found on this forum is to use Maya 2020"
Could you please point me to some of the specific threads that are discussing this issue? I would like to know more about this subject.
Thanks!
gekido
gekido
Posts: 60, Visits: 244
fwiw In a realtime engine you'd probably want to enable tesselation in whatever shader you're using to achieve the same type of smoothing in-engine that you can see in Daz or CC.
www.twitter.com/gekido
