Character reverts back to origin point when released from path
Posted By jeffkirkland 3 Years Ago
Darren01
Darren01
Distinguished Member (6.5K reputation)Distinguished Member (6.5K reputation)Distinguished Member (6.5K reputation)Distinguished Member (6.5K reputation)Distinguished Member (6.5K reputation)Distinguished Member (6.5K reputation)Distinguished Member (6.5K reputation)Distinguished Member (6.5K reputation)Distinguished Member (6.5K reputation)
Last Active: 4 Months Ago
Posts: 654, Visits: 4.1K
I have posted this problem (including on the feedback tracker) since version 6
For some reason, RL has chosen to do nothing about it.
It is very frustrating to the point I won't use the path tool
It has been suggested a work around is to link your avatar or object to a dummy prop which is attached to the path. You then unlink your object/avatar from the dummy once you want it to leave the path. That works to a point, but the object/avatar doesn't adopt all of the characteristics that it would if it was linked directly to the path.
Reallusion PLEASE FIX THIS PROBLEM!!
_________________________________________________________
jeffkirkland
jeffkirkland
Last Active: 8 Months Ago
Posts: 290, Visits: 1.7K
Thanks everyone. I'll use Planet's solution to get me out of trouble and hope IC8 fixes the issue when it finally arrives.
Jeff Kirkland | Director • Cinematographer • Storyteller
Hobart • Tasmania • www.one18films.com
SYSTEM: AMD Ryzen 5 5500 | 32gb RAM | RTX 3060 12gb | 1tb SSD System | 44tb HDD Storage
Posts: 5.3K, Visits: 16.8K
This is how you break off /release in the middle of the path and seamlessly add another clip: https://forum.reallusion.com/FindPost450516.aspx
mark
mark
Posts: 4.9K, Visits: 16.7K
That issue popped up a patch or so ago. It is a known issue I believe. Hopefully it will be fixed in the next version or we'll have an even better method of locomotion control! :D
Until then Planet's suggestion of using an "intermediate" object/dummy between the Path and the "linked" Avatar on the Path should help..;)
PROMO-BACK2
planetstardragon
planetstardragon
Distinguished Member (24.1K reputation)Distinguished Member (24.1K reputation)Distinguished Member (24.1K reputation)Distinguished Member (24.1K reputation)Distinguished Member (24.1K reputation)Distinguished Member (24.1K reputation)Distinguished Member (24.1K reputation)Distinguished Member (24.1K reputation)Distinguished Member (24.1K reputation)
Posts: 11.5K, Visits: 46.0K
some motions are just hard coded like that to a location
one possible way to circumvent this without dramatically changing your workflow .....have the character attached to a dummy prop, and have the dummy prop follow the path - this way when you release it -  the character stays wherever the dummy prop stays.
"To define Tao is to defile it" - Lao Tzu
jeffkirkland
jeffkirkland
Hey everyone,
This is my day for asking what are probably dumb questions but this has been bothering me for a while and searching hasn't helped. I've even resorted  to actually reading the user guide..
When I use a path to animate a character walking, I get to the end and want to release them from the path so I can do other animation in the new location. As soon as I relase an avatar, they head back to their origin point. I'm sure I've used paths where that hasn't happened. What have I missed?
