dj110758
dj110758
Visits: 14
Hi friends, I have a problem with headshot plugin... When generating character it always stop with the image message below ... PPlease help me .....
Posts: 5.7K,
Can you post some examples of the photos causing this issue? It would make finding a solution a lot easier.
dj110758
dj110758
Visits: 14
Thank's for your response, this is photo that i used
Visits: 22.1K
Works for me (I didn't try and fix anything but this is just it raw).
dj110758
dj110758
Visits: 14
It means the problem is in my headshot plugin or my CC 3.4, what should i do ?
Visits: 22.1K
Well, for sure you can delete CC from your machine completely and then let the Reallusion Hub reinstall everything correctly. That's the best procedure and certainly can't hurt.
2 Years Ago by
Last Active: 10 hours ago
Posts: 23.1K,
Visits: 36.5K
dj110758 (2/2/2022) It means the problem is in my headshot plugin or my CC 3.4, what should i do ?Try completely shutting down your computer and restart. If the photo still won't work, try a few different photos. However, if the problem continues try uninstalling Character Creator 3 and the Headshot Plug-in using the Reallusion Hub. Then try a reinstall. Do make sure to install Character Creator 3 first, then the Headshot Plug-in (with CC3 closed down)and ensure everything is working before making any other changes or installing any other plug-ins.
