Headshot plugin failed to detect face
https://forum.reallusion.com/Topic506021.aspx
Print Topic | Close Window
By dj110758 - 4 Years Ago
Hi friends,
I have a problem with headshot plugin...
When generating character it always stop with the image message below ...https://forum.reallusion.com/uploads/images/87ec4875-9801-448d-9459-a47e.pngPPlease help me .....
By wires - 4 Years Ago
Can you post some examples of the photos causing this issue? It would make finding a solution a lot easier.
Thank's for your response, this is photo that i usedhttps://forum.reallusion.com/uploads/images/85be70a4-9e40-41b6-af63-5d10.jpg
By Kelleytoons - 4 Years Ago
Works for me (I didn't try and fix anything but this is just it raw).
https://forum.reallusion.com/uploads/images/cda636af-b76c-41bf-9047-f9d6.jpg
It means the problem is in my headshot plugin or my CC 3.4,  what should i do ?
Well, for sure you can delete CC from your machine completely and then let the Reallusion Hub reinstall everything correctly.  That's the best procedure and certainly can't hurt.
By Peter (RL) - 4 Years Ago
dj110758 (2/2/2022)
Try completely shutting down your computer and restart. If the photo still won't work, try a few different photos. However, if the problem continues try uninstalling Character Creator 3 and the Headshot Plug-in using the Reallusion Hub. Then try a reinstall. Do make sure to install Character Creator 3 first, then the Headshot Plug-in (with CC3 closed down)and ensure everything is working before making any other changes or installing any other plug-ins.
