shotty_858434
shotty_858434
Visits: 132
Thank you. I will check to make
planetstardragon
planetstardragon
Posts: 11.5K,
Visits: 46.0K
make sure you selected the character on the root node / rig - and not a body part / attachment / accessory. That response usually pops up when you chose an incompatible part - so for example on the monsters - make sure you choose the rigged part of the body, and not something like the tail or ears. - it's fairly easy to select an accessory by accident when using a character with a lot of attachments.
shotty_858434
shotty_858434
Visits: 132
I was using a monster with motions as a prop. Now when I load this scene and try to use its motions, I receive an error message. The motions come with the avatar and I used them before. How can I fix this?
