By shotty_858434 - 5 Years Ago
I was using a monster with motions as a prop. Now when I load this scene and try to use its motions, I receive an error message. The motions come with the avatar and I used them before. How can I fix this?
By planetstardragon - 5 Years Ago
make sure you selected the character on the root node / rig - and not a body part / attachment / accessory.
That response usually pops up when you chose an incompatible part - so for example on the monsters - make sure you choose the rigged part of the body, and not something like the tail or ears. - it's fairly easy to select an accessory by accident when using a character with a lot of attachments.
Thank you. I will check to make
