Can Not Replace Motion:
Posted By shotty_858434 5 Years Ago
shotty_858434
shotty_858434
Veteran Member (544 reputation)Veteran Member (544 reputation)Veteran Member (544 reputation)Veteran Member (544 reputation)Veteran Member (544 reputation)Veteran Member (544 reputation)Veteran Member (544 reputation)Veteran Member (544 reputation)Veteran Member (544 reputation)
Posts: 32, Visits: 132
I was using a monster with motions as a prop. Now when I load this scene and try to use its motions,  I receive an error message.
The motions come with the avatar and I used them before.
How can I fix this?
https://forum.reallusion.com/uploads/images/ac5a5b2c-be18-4139-889e-a801.png
planetstardragon
planetstardragon
Distinguished Member (24.1K reputation)Distinguished Member (24.1K reputation)Distinguished Member (24.1K reputation)Distinguished Member (24.1K reputation)Distinguished Member (24.1K reputation)Distinguished Member (24.1K reputation)Distinguished Member (24.1K reputation)Distinguished Member (24.1K reputation)Distinguished Member (24.1K reputation)
Posts: 11.5K, Visits: 46.0K
make sure you selected the character on the root node / rig -  and not a body part / attachment / accessory.
That response usually pops up when you chose an incompatible part  -  so for example on the monsters -  make sure you choose the rigged part of the body,  and not something like the tail or ears. - it's fairly easy to select an accessory by accident when using a character with a lot of attachments.
"To define Tao is to defile it" - Lao Tzu
shotty_858434
shotty_858434
Thank you. I will check to make
