How to assign a motion to an ActorCore actor in Unreal Engine?
Posted By Bridgette_RL 4 Years Ago
Bridgette_RL
Bridgette_RL
Posts: 79, Visits: 689
If you use ActorCore motions, you'll need to select the target character within the Download Settings if you want to start downloading animations. Afterwards, you can use the Auto Setup plugin provided by Reallusionto bring the character along with its motions to Unreal Engine.
If you want to use "your own set" of motions on an ActoreCorecharacter in Unreal, you can take a look at this video to learn about the motion re-targeting process. The mapping file mentioned in the video can be downloaded here: https://file.reallusion.com/Retarget.zip
1. Open the character's Skeleton, and go to Retarget Manager panel.
Select Rig to Humanoid Rig.
2. Load the remapping file. You can download it from https://file.reallusion.com/Retarget.zip
3. Go to Skeleton Tree panel, and select entire cc_base skeleton.
Right click to Recursively Set Translation Retargeting Skeleton.
Apply to Asset to the target character.
4. Find your desired motion and right click to Retarget Anim Assets >> Duplicate Anim Assets and Retarget.
Make sure to select the target skeleton. In this case is Party_M_0003_Skeleton.
Finally, you can apply your custom motions to ActorCorecharacters.
Threaded View
