"Failed to load the file" when opening project
Posted By _RESERVED__219337 4 Years Ago
Cary B
Cary B
Posts: 478, Visits: 3.8K
Yeah, looks like this old thread was resurrected by someone who was having the same issue with Iclone 8 as the old Iclone 7 issue. I am having the same "Failed to Load File"  issue with Iclone 8, as I see others are. I will start a new thread, and hope others will share their experiences with this issue.
https://forum.reallusion.com/uploads/images/848c8492-ac67-42c2-9d27-461e.jpg
Posts: 23.1K, Visits: 36.6K
djjuanitopresents (7/30/2022)
Nope! It's not a "Hard drive issue" This is happening to me too! It just started out of the blue! I've been doing everything the same for years! My computer is new and loaded!
This is the iClone 7 archive forum. Are you having problems with projects not loading in iClone 7 or iClone 8. If it is iClone 8 please post questions and report issues in the correct forum.
If it is iClone 7, does the issue happen with all projects or just one? Also do you have any problems loading the sample projects that come with iClone?
djjuanitopresents
djjuanitopresents
New Member (32 reputation)New Member (32 reputation)New Member (32 reputation)New Member (32 reputation)New Member (32 reputation)New Member (32 reputation)New Member (32 reputation)New Member (32 reputation)New Member (32 reputation)
Posts: 2, Visits: 201
Cary B
Cary B
I have had very similar "Failed to Load File" issues. It has happened many times with many different projects. I thought perhaps my files were too big, but many of my biggest projects would still open, while smaller ones would not.
So far in my experiments, it seems that the projects which fail to open are ones which used several of my legacy animations. I have many old animations that I converted, including Mixamo animations that I had converted using 3Dxchange. These would seem to work in Iclone 8, though sometimes I would get a message about having to "update" the motion when I applied it.
I am not positive, but I suspect that the projects which use a lot of these old animations are the ones which fail to load. I have avoided using the old animations in recent projects and have not had the problem again so far.
There are some old horse animations I use extensively from an old Iclone product. I have tried applying these animations then using a "collect clip" to replace them with a new clip before saving the project. This may have helped. I have also been very careful about trying to keep the size of my projects smaller, much smaller than what I used in Iclone 7.
There is another thread about animations that are ballooning in size in the forum which may be related to this, not sure:  "Saved Project is Gigantic"
jimsebor (6/26/2022)
I have the same issue with Iclone8 "failed to load project" My hardrive is fine and I didn't do anything unusual. I put a few hours into this project, hopefully reallusion will get this kink out soon.
Is this a project created in iClone 8 or one originally from iClone 7? Also what is the size of the project (file size/triangle count)
jimbobway
jimbobway
New Member (68 reputation)New Member (68 reputation)New Member (68 reputation)New Member (68 reputation)New Member (68 reputation)New Member (68 reputation)New Member (68 reputation)New Member (68 reputation)New Member (68 reputation)
Last Active: 7 Months Ago
Posts: 3, Visits: 193
_RESERVED__219337 (4/16/2021)
The previous files used to open but now they also give the same error. I tried starting completely over and the same thing seemed to happened.
Thanks for explaining more. Sounds like a possible hard drive issue if all projects are affected.
If you have another hard drive, try saving your projects to the different drive. If they save and load ok then that would indicate you have problem with the hard drive you were using. It would also be worth right clicking the hard drive in Windows Explorer, choose Properties and then the Tools tab. Then run an error check on the drive and also defrag it in case that is the issue.
If the drive checks out ok, then you may need to uninstall iClone and do a clean install just to eliminate a faulty install as the problem.
_RESERVED__219337
_RESERVED__219337
Senior Member (255 reputation)Senior Member (255 reputation)Senior Member (255 reputation)Senior Member (255 reputation)Senior Member (255 reputation)Senior Member (255 reputation)Senior Member (255 reputation)Senior Member (255 reputation)Senior Member (255 reputation)
Posts: 3, Visits: 144
Peter (RL) (4/15/2021)
Hi...
If you have been working on the project for the last couple of weeks do you have an earlier build from a day or so ago that you can try to load? This will help determine if the problem is with something you did to the project in the last time you worked on it. Also do other projects like the samples that come with iClone still load okay?
_RESERVED__219337
_RESERVED__219337
I can! I can open up some of the earlier files but I feel like  even some of the older files are becoming corrupt and not letting me open them. Really weird.
So basically, every night that I'd work on it I would save a couple different files just in case. Some of them would open and some of them wouldn't. So I'm not sure if something's going wrong in the save process or if something in the project is causing it to act that way.
But yeah, some of my other past projects still open alright.
Hi...
