lightbearer
lightbearer
Last Active: 8 Months Ago
Visits: 530
I'm not sure why this is happening. The top image is a "full" Cycles render in Blender 2.93. The bottom image is a Material Preview using the View-->Viewport Render Image. I'm using the CC Blender Tools. Skin looks fine in Eevee, but I can't figure out what's wrong with the Cycles render. I have adjusted SSS (even zeroing it out) and it doesn't seem to help. Suggestions?
jeff.davies
jeff.davies
Visits: 1.5K
When you switched to cycles did you rebuild the materials using the CC3 blender addon? Also, you might check the shader material for the skin to ensures the image texture is marked as srgb instead of nocolor
- Jeff The Adventures of Capt Sanchez Cybernautic Studios
lightbearer
lightbearer
Visits: 530
I did use the CC3 add on to rebuild the shader. I have not checked that the shader is using the sRGB. Will check now.
Victor.Soupday
Victor.Soupday
Visits: 9.0K
Which version of the add-on are you using?
Older versions used to do something like that in Cycles.
lightbearer
lightbearer
Visits: 530
Map heading into the shader node was/is designated as sRGB.
lightbearer
lightbearer
Visits: 530
Using 1.2.2
But I think I figured it out. I had Rebuild Advanced Materials selected. When I used Rebuild Basic Materials, the skin looks "normal."
lightbearer
lightbearer
Visits: 530
In your opinion, is there a way to keep the flexibility of using the Advanced Shader and the various tweaks in this situation?
Victor.Soupday
Victor.Soupday
Visits: 9.0K
It looks like there either entirely too much subsurface or there's some emission in there.
Check that the emission settings are all set to zero.
In the material nodes on the skin shader, is anything plugged into the subsurface radius socket? (There's not supposed to be.)
Were the materials in the blend file originally built with an older version of the add-on?
lightbearer
lightbearer
Visits: 530
Here is a picture of the node structure, if it helps.
I've been working on the project for a little more than a week now, so I believe everything was brought in under v 1.2.2, but I can't rule out that I used an earlier version of the plugin (though I don't believe so).The Emission Strength on the Head Skin Shader is set to 1. I did zero it out and it shows the same result.
Worse case scenario, I will use the Basic Material. It still looks quite good.
lightbearer
lightbearer
Visits: 530
Image created using the Basic Shader.
