How to flip/mirror actor to face other direction?
Posted By mikeoui 3 Years Ago
mikeoui
mikeoui
Senior Member (302 reputation)Senior Member (302 reputation)Senior Member (302 reputation)Senior Member (302 reputation)Senior Member (302 reputation)Senior Member (302 reputation)Senior Member (302 reputation)Senior Member (302 reputation)Senior Member (302 reputation)
Posts: 10, Visits: 54
Hi all,
I am certain this must be easy to do, but after searching here, searching Facebook groups, and rewatching an hour of tutorials, I still can’t figure out how to mirror a character to be facing the other direction.
I previously asked someone if a character can be flipped and was told yes and given an image, but I didn’t ask how at the time.
Thanks,
Mike
Martin Scorsese
Martin Scorsese
Senior Member (478 reputation)Senior Member (478 reputation)Senior Member (478 reputation)Senior Member (478 reputation)Senior Member (478 reputation)Senior Member (478 reputation)Senior Member (478 reputation)Senior Member (478 reputation)Senior Member (478 reputation)
Posts: 5, Visits: 33
Hi Mike;
Select the character you want, go to the tool bar, click on the two arrowheads facing each other, one outlined one filled. Done. It also does vertical flips.
Martin
https://forum.reallusion.com/uploads/images/001f36f8-14b1-4dee-9cb2-12ff.jpg
vepop
vepop
Distinguished Member (6.0K reputation)Distinguished Member (6.0K reputation)Distinguished Member (6.0K reputation)Distinguished Member (6.0K reputation)Distinguished Member (6.0K reputation)Distinguished Member (6.0K reputation)Distinguished Member (6.0K reputation)Distinguished Member (6.0K reputation)Distinguished Member (6.0K reputation)
Posts: 1.0K, Visits: 9.9K
https://forum.reallusion.com/uploads/images/71f8febc-3c8a-445d-a3b3-b9e7.gif
https://forum.reallusion.com/uploads/images/9331d0a4-6a4b-4e86-9f88-963f.jpg
YouTube Tutorials Here
charles329
charles329
Junior Member (182 reputation)Junior Member (182 reputation)Junior Member (182 reputation)Junior Member (182 reputation)Junior Member (182 reputation)Junior Member (182 reputation)Junior Member (182 reputation)Junior Member (182 reputation)Junior Member (182 reputation)
Last Active: 10 Months Ago
Posts: 8, Visits: 2.7K
Hi...thank you. Can you do the same in iclone? I know you can do it as a pose but what about when you have animation like two people dancing together?
Distinguished Member (124.0K reputation)Distinguished Member (124.0K reputation)Distinguished Member (124.0K reputation)Distinguished Member (124.0K reputation)Distinguished Member (124.0K reputation)Distinguished Member (124.0K reputation)Distinguished Member (124.0K reputation)Distinguished Member (124.0K reputation)Distinguished Member (124.0K reputation)
Last Active: Today @ 2:59 AM
Posts: 23.1K, Visits: 36.5K
charles329 (1/18/2021)
Hi Charles
For iClone questions please try to post them in the iClone forum rather than here in the Cartoon Animator forum which has a different user base.
However, to answer your question, iClone doesn't need a flip button for characters because characters in iClone are 3D and can be rotated to any angle you want. But for motion clips you can't flip these but you will find that most motion clips intended for two people such as talking, hugging or dancing will come with both the right and left side versions so you can apply them to both characters.
pete_20090922184254699
Posted Last Year
Veteran Member (649 reputation)Veteran Member (649 reputation)Veteran Member (649 reputation)Veteran Member (649 reputation)Veteran Member (649 reputation)Veteran Member (649 reputation)Veteran Member (649 reputation)Veteran Member (649 reputation)Veteran Member (649 reputation)
Posts: 13, Visits: 64
Hi Group
Further to this old question, am I correct in saying that if your character has an obviously asymmetrical element to their clothing, say a name badge or shirt logo/number (e.g., in the case of a sportsperson), that you'd need to create a whole new character with their clothing reversed so when you flipped it to a pose/action going back the other way the words etc that were on the clothing weren't reversed?
Thanks for any confirmation and/or point in the right direction.
PeteB
Posted Last Year
pete_20090922184254699 (8/28/2023)
Hi Group
Unfortunately if you use clothing that has badges or logos on one side then they will appear to change to the other side when using Flip. Obviously if you plan on using Flip then it is best not to use any asymmetrical clothing if you can, or as you have already surmised, you will need to have two characters, one facing left and one facing right.
Tip: If your character has a prop attached to one hand this will also appear to switch to the other hand when using Flip. A good way to work around this is to have the same object in both hands to start with and then make one invisible. Then when you use Flip you can make the other prop visible and hide the first one. This will give the effect of the attached prop staying in the correct hand.
Last Year by Peter (RL)
Posted Last Year
Brilliant! Thanks for the tip, Peter.
