pete_20090922184254699 (8/28/2023)
Hi Group
Further to this old question, am I correct in saying that if your character has an obviously asymmetrical element to their clothing, say a name badge or shirt logo/number (e.g., in the case of a sportsperson), that you'd need to create a whole new character with their clothing reversed so when you flipped it to a pose/action going back the other way the words etc that were on the clothing weren't reversed?Unfortunately if you use clothing that has badges or logos on one side then they will appear to change to the other side when using Flip. Obviously if you plan on using Flip then it is best not to use any asymmetrical clothing if you can, or as you have already surmised, you will need to have two characters, one facing left and one facing right.
Tip: If your character has a prop attached to one hand this will also appear to switch to the other hand when using Flip. A good way to work around this is to have the same object in both hands to start with and then make one invisible. Then when you use Flip you can make the other prop visible and hide the first one. This will give the effect of the attached prop staying in the correct hand.
Last Year by
