iClone7 is so slow, it's not possible to work with it..
Posted By eylonedri 5 Years Ago
3
oisilener1982
oisilener1982
Posts: 190, Visits: 1.4K
deanmorrissey (11/23/2020)
 You definitely need to upgrade to Ryzen 5800x to 5950x if you want to work with 1.76M Project Triangle.
r78zj99
r78zj99
Veteran Member (528 reputation)Veteran Member (528 reputation)Veteran Member (528 reputation)Veteran Member (528 reputation)Veteran Member (528 reputation)Veteran Member (528 reputation)Veteran Member (528 reputation)Veteran Member (528 reputation)Veteran Member (528 reputation)
Posts: 122, Visits: 203
hi oisilener1982 & all
I notice that your graphic ram is low you may need to upgrade!
as for other members the error messages
well it maybe an good idea to clean up your registry because it members your last actions!
from Alan
 hope this helps
happy animations everyone
r78zj99
r78zj99
hi all
extra tip, when iclone is starting up take a look at the splash screen
in the bottom left hand corner, you will see each of your plug in loading up.
so, if a error pop up on your screen remember what point it did at!
so, if this is a real problem the team maybe able to fix it.
helping all
from Alan
Deanius 3D
Deanius 3D
Senior Member (281 reputation)Senior Member (281 reputation)Senior Member (281 reputation)Senior Member (281 reputation)Senior Member (281 reputation)Senior Member (281 reputation)Senior Member (281 reputation)Senior Member (281 reputation)Senior Member (281 reputation)
Posts: 15, Visits: 533
Hi mate.
You say that my graphic RAM is low, but it does not seem to be utilised to the potential.  Why would I need to upgrade if only 50% of it is being used?  That seems odd.
Dean
r78zj99
r78zj99
sorry about that mis-understanding deanmorrissey
it was oisilener1982
ram being at 2gb
as know sometimes it is shared
from Alan
eylonedri
eylonedri
Senior Member (252 reputation)Senior Member (252 reputation)Senior Member (252 reputation)Senior Member (252 reputation)Senior Member (252 reputation)Senior Member (252 reputation)Senior Member (252 reputation)Senior Member (252 reputation)Senior Member (252 reputation)
Posts: 6, Visits: 81
hey r78, I'm not sure I'm following- how's the USB related to the slow processing problem during editing or after recording?
When I edit the files I don't use any external devices, it's all on PC, and the processing problems with the records starts after I already done shooting the mo-cap take, so I don't think a USB has to do anything with it, am I missing something?
r78zj99
r78zj99
hi eylonedri
as you know motion capture is done as a live feed on data transfer at the same rate as you capture!
using a usb
I am using the old Xbox capture system this works very well for me but it requirements states a usb of version 3 is needed other wise the software refuses to operate!
I suggest that you make you movements into smaller parts than reaching a timeout situation!
not forgetting to save your work after every motion
start and stop
example can start like this see below
motion 1, motion 2 and so on
saving after each motion
hope, I have been helpful
from Alan
  happy animations
eylonedri
eylonedri
hey Alan, thanks for the reply
just to make sure, you suggest not to cross a recording time of about a minute~minute and a half at max? otherwise iClone7 will struggle editing long mo-cap clips?
thanks
Eylon
r78zj99
r78zj99
hi eylonedri
again, yes it is all about not putting a load on your machine as you have told us earlier with your task manager
you can closed programmes down that are not needed!
well also the same thing can be done in iclone
as not to overload things
so here rule --- the more complicated your scene is the more load is placed onto your machine.
most motion action is done with a plain background
the scene is added later
I do hope, I have been of some help to you
esemgee
esemgee
Posts: 168, Visits: 469
iClone is a machine eater and I have had problems since iClone 5, especially with render times. I have found that as long as I have about 125 GB free on my C drive (it's a 256 SSD so constantly having to clean it of unwanted stuff) it works reasonably well, though again the rendering time has led me into caffeine addiction*. I have argued elsewhere on this forum that RL really needs to redesign IC from the ground up, as its updates and extras, fantastic as there are, seem to be sitting on an aging engine. Proof would be things like that now clothes seem to rip and tear much more easily; the basics that used to work OK are now falling apart. Nearly all the working content of iClone is in a folder called 'template', no problem it could be called 'Henry', but that particular name bothers me, it's as if the original iClone never had faith it would grow into quite a beast, so never bothered with a logically named file system.
And that maybe the problem @eylonedri is having - iClone has a confusing 'road' system that could do with some reroutes, and faster lanes!
*another thing that may have helped was I turned on GeForce Experience. I have no idea what it is or what it does but since it being on iClone seems faster (though not in the rendering)
3
