SeanMac
SeanMac
Visits: 3.4K
Thanks, man.
A change is as good as a rest. Regards
SeanMac
Lord Ashes
Lord Ashes
Posts: 1.3K,
Visits: 1.6K
SeanMac (10/6/2020) @Ashes Finding yourself reading the same joke a dozen times gets tedious. Could you please change your joke. referably for something other than a joke? Regards SeanMac
How about these song lyrics...
SeanMac
SeanMac
Visits: 3.4K
@Ashes Re: "We often compare ourselves to the US..." Finding yourself reading the same joke a dozen times gets tedious. Could you please change your joke. referably for something other than a joke? Regards SeanMac
Lord Ashes
Lord Ashes
Posts: 1.3K,
Visits: 1.6K
The added code does indeed work. However, there is no explanation as to what this method call actually does (and thus why it works). It is not documented in the RGlobal namespace ( https://wiki.reallusion.com/IC_Python_API:RLPy_RGlobal).
Lord Ashes
Lord Ashes
Posts: 1.3K,
Visits: 1.6K
Have not tried it myself yet but sounds like its a solution. Thanks Allen Lee and videodv.
videodv
videodv
Visits: 12.0K
AllenLee (RL) (10/5/2020)
Hi every one, You can try to add this. # This API can trigger other UI updates.RLPy.RGlobal.ObjectModified(avatar, RLPy.EObjectModifiedType_Transform)
Allen Lee Hi Allen Lee Just tried this and it worked fine. Thanks Chris.
AllenLee (RL)
AllenLee (RL)
Last Active: 9 Months Ago
Visits: 541
Allen Lee
Lord Ashes
Lord Ashes
Posts: 1.3K,
Visits: 1.6K
No just straight default settings, i used cc3 jade in the example will test cc3+ character tomorrow Chris
Maybe that is what 4u2ges was eluding to...that it does not work with CC3+ characters. I'll have to try it with CC3 and older characters.
videodv
videodv
Visits: 12.0K
Lord Ashes (10/4/2020)
videodv (10/4/2020) Hi Lord Ashes Here is the play example as I ran your original script on my system. Chris
I was not getting the same results until I checked the Bake Animation project setting. Once I did that then it generated the key frames. Are you using that option? Hi No just straight default settings, i used cc3 jade in the example will test cc3+ character tomorrow Chris
Last Active: 10 days ago
Posts: 5.3K,
Visits: 16.8K
OK got it! :) Any character without Persona applied would not update Timeline after loading Bones script regardless. Just remove Persona from any character and run script (with those 2 lines of code Chris suggested) - it would not update the timeline. Add any person back to character and it would update timeline just fine. RL CC3+ characters do not have Persona applied, that is why it was confusing. BUG!
