Scripted Bone Rotations Not Showing Up As Motion Or Motion Layer Key Frames
Posted By Lord Ashes 5 Years Ago
Scripted Bone Rotations Not Showing Up As Motion Or Motion Layer Key...
Lord Ashes
Lord Ashes
Posts: 1.3K, Visits: 1.6K
As my introduction to Python scripting, I created a Python script to change the rotation of an Avatar's heard. I have the script working and when I apply it to an Avatar and play, the rotation is there. That is good.
However, the issue is that when I look at my timeline for the Avatar I don't see any key frames on the Transform layer (didn't expect any there since this is a head animation) but I also don't get any key frames on the Motion, Motion | Gesture, Motion | Motion Layer or Motion | Motion Layer | Head layer where I expected to find some keys to reflect the script added rotation.
As far as I can see, currently there is no evidence on the time line that a rotation should be applied to the head but the playback clearly shows one.
Is there something that I need to add to my script in order to update the key frames? Should my script be setting the bone rotation in a different way in order to produce key frames?
The current code that I am using is:
import RLPy
print("Get Avatar")
avatar = RLPy.RScene.GetSelectedObjects()[0]
print("Get Bones")
motion_bones = avatar.GetSkeletonComponent().GetMotionBones()
print("Get Head Bone")
bone = motion_bones[0]
for this_bone in motion_bones:
  if this_bone.GetName() == "RL_Head":
    bone = this_bone
    break
print("Create clip")
clip = avatar.GetSkeletonComponent().AddClip(RLPy.RGlobal.GetTime())
clip.SetLength(RLPy.RTime(150*1000))
print("Grab bone")
control = clip.GetControl("Layer", bone).GetDataBlock().GetControl("Rotation/RotationY")
print("Rotating...")
rotation_y = -45
frame = 0
for loop in range(16):
    print("Setting Rotation %d At Time Frame %d." %(rotation_y, frame))
    control.SetValue(RLPy.RTime(frame/60*1000, RLPy.kMilliseconds), rotation_y / 180 * RLPy.RMath.CONST_PI)
    rotation_y = rotation_y + 5
    frame = frame + 10
print("Done")
Threaded View
Threaded View
Forum Post Scripted Bone Rotations Not Showing Up As Motion Or Motion Layer Key... By Lord Ashes ( 5 Years Ago )
Forum Post I am not sure to call it a bug or not, but the keyframes would appear... By 4u2ges ( 5 Years Ago )
Forum Post [quote][b]Lord Ashes (10/3/2020)[/b][hr]As my introduction to Python... By videodv ( 5 Years Ago )
Forum Post [quote] Try putting this bit of code after the final loop and before... By Lord Ashes ( 5 Years Ago )
Forum Post [quote][b]Lord Ashes (10/3/2020)[/b][hr][quote] Try putting this bit... By videodv ( 5 Years Ago )
Forum Post [quote] Hi Lord Ashes In order to see the keys on the timeline you... By Lord Ashes ( 5 Years Ago )
Forum Post I have tried both suggestions: 1. To put the stop code at the end.... By Lord Ashes ( 5 Years Ago )
Forum Post Hi Lord Ashes Here is the play example as I ran your original script... By videodv ( 5 Years Ago )
Forum Post [quote][b]videodv (10/4/2020)[/b][hr]Hi Lord Ashes Here is the play... By Lord Ashes ( 5 Years Ago )
Forum Post [quote][b]Lord Ashes (10/4/2020)[/b][hr][quote][b]videodv... By videodv ( 5 Years Ago )
Forum Post [quote] No just straight default settings, i used cc3 jade in the... By Lord Ashes ( 5 Years Ago )
Forum Post [quote]HI Try putting this bit of code after the final loop and... By 4u2ges ( 5 Years Ago )
Forum Post This whole thing with timeline update is still buggy. I know at least... By 4u2ges ( 5 Years Ago )
Forum Post It's Caleb a problem (maybe some other too). If you try it with Caleb... By 4u2ges ( 5 Years Ago )
Forum Post [quote][b]4u2ges (10/4/2020)[/b][hr]It's Caleb a problem (maybe some... By Lord Ashes ( 5 Years Ago )
Forum Post Yes, it is still a bug with CC3+ (default RL characters, converted... By 4u2ges ( 5 Years Ago )
Forum Post OK got it! :) Any character without Persona applied would not update... By 4u2ges ( 5 Years Ago )
Forum Post Hi every one, You can try to add this. # This API can trigger... By AllenLee (RL) ( 5 Years Ago )
Forum Post [quote][b]AllenLee (RL) (10/5/2020)[/b][hr]Hi every one, You can try... By videodv ( 5 Years Ago )
Forum Post Have not tried it myself yet but sounds like its a solution. Thanks... By Lord Ashes ( 5 Years Ago )
Forum Post The added code does indeed work. However, there is no explanation as... By Lord Ashes ( 5 Years Ago )
Forum Post @Ashes Re: "We often compare ourselves to the US..." Finding yourself... By SeanMac ( 5 Years Ago )
Forum Post [quote][b]SeanMac (10/6/2020)[/b][hr]@Ashes Finding yourself reading... By Lord Ashes ( 5 Years Ago )
Forum Post Thanks, man. A change is as good as a rest. Regards SeanMac By SeanMac ( 5 Years Ago )
