terrain
Posted By evidanse 5 Years Ago
evidanse
evidanse
Posts: 72, Visits: 435
hello
I try to create my own terrain with earth sculptor.
I have a problem : if i use iclone's terrain and modify then with warlord's wery good tutorial indeed) method it works but you can not scale the terrain to x and y axes...
I need and 1024x1024 terrain...
So I created terrains with earth sculptor, import them via 3dx change. I convert then as terrain but in the modify panel, there is no texture panel, and no height map and mask...
Is the a way to make this panels appears or to modify iclone's terrains size ?
Thx
Michelhttps://forum.reallusion.com/uploads/images/d851acde-05db-4165-9305-6b6f.jpghttps://forum.reallusion.com/uploads/images/655674df-5eb2-42ed-b622-d3fe.jpg
Posts: 15.8K, Visits: 31.4K
I'm a bit rusty on this, but the following should work.
To modify a terrain like you created and edit the textures, right-click the terrain and select "Convert to Prop" (something like that).
You can now edit the textures. Once done you can convert back to terrain.
evidanse
evidanse
hi
I tried to convert iclone's terrain to prop but they are locked...
There is not the convert option with the right click...
thebiz.movies
thebiz.movies
Distinguished Member (14.4K reputation)Distinguished Member (14.4K reputation)Distinguished Member (14.4K reputation)Distinguished Member (14.4K reputation)Distinguished Member (14.4K reputation)Distinguished Member (14.4K reputation)Distinguished Member (14.4K reputation)Distinguished Member (14.4K reputation)Distinguished Member (14.4K reputation)
Last Active: 3 Weeks Ago
Posts: 2.1K, Visits: 42.3K
Yea I don't think you can convert those large terrains with height/texture maps to props.
evidanse
evidanse
So is there a way to create any large terrain with height map and mask ?
Postfrosch
Postfrosch
Distinguished Member (39.0K reputation)Distinguished Member (39.0K reputation)Distinguished Member (39.0K reputation)Distinguished Member (39.0K reputation)Distinguished Member (39.0K reputation)Distinguished Member (39.0K reputation)Distinguished Member (39.0K reputation)Distinguished Member (39.0K reputation)Distinguished Member (39.0K reputation)
Posts: 6.9K, Visits: 18.4K
look this picture
https://forum.reallusion.com/uploads/images/f44a3ec4-2076-4a2a-947c-5ad3.jpg
Greets Postfrosch
evidanse
evidanse
Hello
use well earth creator.
But the created terrain does not keep the mask and height map to be modify in iclone like the native icone terrains and use iclone textures...
Postfrosch
Postfrosch
It's Earth Sculptor
Click "Export"
Click "Highmap Image"
Click"Export" " Terrain Texture"
Load this Textures in IClone
Greets Postfrosch
evidanse
evidanse
Yes I know but the material panel does not appearshttps://forum.reallusion.com/uploads/images/80b429cc-5916-41e9-a786-ad38.jpghttps://forum.reallusion.com/uploads/images/effbe4d3-1046-4748-9076-1159.jpg
thebiz.movies
thebiz.movies
I think postfrosch is saying you generate the images in Earth Sculptor and then replace the images on your default large terrain that allows those images..
