hello
I try to create my own terrain with earth sculptor.
I have a problem : if i use iclone's terrain and modify then with warlord's wery good tutorial indeed) method it works but you can not scale the terrain to x and y axes...
I need and 1024x1024 terrain...
So I created terrains with earth sculptor, import them via 3dx change. I convert then as terrain but in the modify panel, there is no texture panel, and no height map and mask...
Is the a way to make this panels appears or to modify iclone's terrains size ?
Thx
Michel
