Mythcons
Mythcons
Last Active: 3 Weeks Ago
Visits: 3.2K
This will be my second submission when he is finished. I decided I wanted to work on a large, stylized character. I took my Earthquake morph and used it as a base to sculpt a new character. First I gathered some references. Again I am using One Piece as a source for inspiration. There is is a variety of larger characters in that series to draw reference from. I decided to use Blender as my subscription for Zbrush recently expired and I'm in a frugal mindset these days. Also, there's nothing wrong with Blender's sculpting capabilities. I ended up with this morph being imported back into Character Creator from Blender. I put a Cartoon texture on him, converted from the Reallusion 'Cartoon Character Designer' pack. I then went into SkinGen and added some basic presents, such as body hair, dull eyes, and added some coloration to his face. I have not yet finished with this process. I then took a render of this character morph and sketched some armor on him in an illustration application. I ended up going with a gluttonous, viking barbarian type character. This is currently where I'm at with the character. I really liked the idea of him eating a large drum stick while engaged in combat.
uvz
Last Active: 4 hours ago
Visits: 512
Bro, Please do the Blender Pipeline Tutorial for the benefit of those who can not afford ZBrush like me.
Many Thanks In Advance
Mythcons
Mythcons
Visits: 3.2K
uvz (9/6/2020) Bro, Please do the Blender Pipeline Tutorial for the benefit of those who can not afford ZBrush like me.
Sure thing. 1) Export your model using OBJ > Nude character in bind-pose. 2) Import the OBJ into Blender, making sure to retain vertex order and with polygroups checked. (You may be able to split the groups, but I haven't tried). 3) Select your figure geometry and enter the Sculpt tool area. I usually sculpt on a Shapekey, but this is optional. It just gives you greater control over your sculpt, allowing you to dial in or out your changes and various other things. If you use Shapekeys, remember to dial them in before sculpting -- otherwise there will be no changes to your mesh. 4) Export with polygroups, and possibly vertex order kept (I always check it). 5) Create a new morph using the exported OBJ and the accompanying OBJ Key. You can either make the morph a new morph, or you can apply the changes to your existing project character. I generally prefer these options. 6) If you want to apply the changes to your current project, use the 'Target Current Morph' and 'Auto apply to current character'.
matenn30
matenn30
Last Active: 6 days ago
Visits: 3.3K
https://oakcorp.net/pixologic/zbrushcore/https://www.gimp.org/https://store.steampowered.com/app/1194110/Substance_Painter_2020/Above (If you can translate, please translate.) Is it reasonable to use a reasonable price with the url?上記(翻訳可能なら翻訳お願いします。)urlで手ごろソフト値段でもダメですか。
The forum is an amateur. フォーラムは素人です。
uvz
Visits: 512
Mythcons Sir, Many Thanks for sharing your workflow. Will try it out right away. Grateful for your help. Thanks Once Again.
4 Years Ago by
uvz
Mythcons
Mythcons
Visits: 3.2K
I apologize but I don't understand.
Mythcons
Mythcons
Visits: 3.2K
I modified the helmet, but I have yet to texture it so it doesn't appear in the latest render. I also used the Hair Tool for Blender (paid plug-in) to create a beard for him, as I depicted in the sketch. I also used a hair preset to give him actual long hair, separate from the beard. I also gave him a hammer, but I don't yet like the texturing, and may re-do the entire model. It is a simple model with strands of leather, a handle, atop a block of concrete. I used a Red and Green ID map to generate better textures for the armor using Character Creator's Substance interface. Basically this allows you to put leather, fabric, metal, or custom textures immediately on the Red or Green areas. Also Blue if you want a third color.
rosuckmedia
rosuckmedia
Posts: 3.2K,
Visits: 4.7K
Hi Mythcons, I'm not a developer, I think your workflow is very good, Your characters are great Best regards rosuckmedia
4 Years Ago by
rosuckmedia
Mythcons
Mythcons
Visits: 3.2K
rosuckmedia (9/8/2020)
Hi Mythcons, I'm not a developer, I think your workflow is very good, Your characters are great Best regards rosuckmedia Thanks for the kind words. I have actually learned a lot from this contest and have plans for marketplace content.
Miranda (RL)
Miranda (RL)
Posts: 1.8K,
Visits: 11.2K
Thanks for your sharing about Blender settings! Looking forward to seeing more of your creations. Every entrant can submit up to 3 entries, but there is no harm to create more during the contest, and pick up the best three to be the final.
