Less Feature Updates MORE PERFORMANCE
Posted By greggoryaddison 6 Years Ago
Rated 5 stars based on 3 votes.
greggoryaddison
greggoryaddison
Veteran Member (526 reputation)Veteran Member (526 reputation)Veteran Member (526 reputation)Veteran Member (526 reputation)Veteran Member (526 reputation)Veteran Member (526 reputation)Veteran Member (526 reputation)Veteran Member (526 reputation)Veteran Member (526 reputation)
Posts: 15, Visits: 235
I have a pretty nice rig and iclone and the rest of reallusions product put so much strain on my hard ware! How can I improve performance on my end and also could you guys spend some time making the program run better and not just loading it with features!!
Threaded View
Threaded View
Forum Post Less Feature Updates MORE PERFORMANCE By greggoryaddison ( 6 Years Ago )
Forum Post It would help if you posted your PC specs, without those there is no... By wires ( 6 Years Ago )
Forum Post [quote][b]wires (8/9/2020)[/b][hr]It would help if you posted your PC... By greggoryaddison ( 6 Years Ago )
Forum Post If features are not added we get complaints too...:unsure: By animagic ( 6 Years Ago )
Forum Post yeah but bloated and sluggish aren't exactly strong selling points. I... By planetstardragon ( 6 Years Ago )
Forum Post yeah , you're quite right about iClone , although it's easy to use for... By Khalid Abusaud ( 6 Years Ago )
Forum Post I recently upgraded my video card to an rtx 2070 (from 4gb to 8 gb... By thebiz.movies ( 6 Years Ago )
Forum Post My Msi GTX 1070 - is 8 gig ram and overclocks to 1900 mhz on msi... By planetstardragon ( 6 Years Ago )
Forum Post Overclocking doesn't matter here , GPU Ram is important. How many... By StyleMarshal ( 6 Years Ago )
Forum Post it was a cc3 Plus character with some basic cloths I made in MD -... By planetstardragon ( 6 Years Ago )
Forum Post and here's a screen cap as proof - note the red message at the bottom.... By planetstardragon ( 6 Years Ago )
Forum Post ohh , you are talking about Iray. Haven't used it yet. By StyleMarshal ( 6 Years Ago )
Forum Post [quote][b]Bassline303 (8/9/2020)[/b][hr]ohh , you are talking about... By planetstardragon ( 6 Years Ago )
Forum Post [quote][b]planetstardragon (8/9/2020)[/b][hr]and here's a screen cap... By 4u2ges ( 6 Years Ago )
Forum Post I only have a 1080 TI with 11 gigs of memory, and upgrading in 2020... By Data Juggler ( 6 Years Ago )
Forum Post Sorry, folks, if I'm late to the dance. I think the OP as well as Mr.... By Kelleytoons ( 6 Years Ago )
Forum Post I just want to post an update that I found out why my scene was so... By Data Juggler ( 6 Years Ago )
Forum Post I agree with OP 100%. Folks, you do not have to use 4K texture to get... By 4u2ges ( 6 Years Ago )
Forum Post Bassline303, it is not only about Iray. Here is a simple test. 3... By 4u2ges ( 6 Years Ago )
Forum Post I don't have major problems, so I will stay out of the discussion. I... By animagic ( 6 Years Ago )
Forum Post @animagic, whats your optimization work flow ? usually when I go... By planetstardragon ( 6 Years Ago )
Forum Post If you decrease the texture sizes in CC3.3 , you can save GPU Ram,... By StyleMarshal ( 6 Years Ago )
Forum Post @ Bassline303 valid point, I'll mess around with those settings... By planetstardragon ( 6 Years Ago )
Forum Post Also try Texture compression for Iray , I didn't activate it. By StyleMarshal ( 6 Years Ago )
Forum Post Tried new all time lowest settings as apparently I had already tweaked... By planetstardragon ( 6 Years Ago )
Forum Post I had bought Iray render plugin last month and returned and got a... By abcliu ( 6 Years Ago )
Forum Post I'm trying to fix a weightmap for an item i made, it's literally... By planetstardragon ( 6 Years Ago )
Forum Post CC 3.3 does NOT delete the Skingen Temp files from the Temp folder... By Postfrosch ( 6 Years Ago )
Forum Post I am not sure how you got that low VRAM utilization (UNLESS you... By 4u2ges ( 6 Years Ago )
Forum Post I should also mention that the difference between my out of memory... By planetstardragon ( 6 Years Ago )
Forum Post [quote][b]4u2ges (8/9/2020)[/b][hr]I am not sure how you got that low... By StyleMarshal ( 6 Years Ago )
Forum Post I use 2k for the face, 1k for the rest, which has helped me. In one... By animagic ( 6 Years Ago )
Forum Post I agree @animagic with the baking, that can at least help offset... By planetstardragon ( 6 Years Ago )
Forum Post Job, I totally understand what you are saying. I was always advocating... By 4u2ges ( 6 Years Ago )
Forum Post I'm using the word optimization, specifically from my gaming... By planetstardragon ( 6 Years Ago )
Forum Post I hear you... :) By 4u2ges ( 6 Years Ago )
Forum Post we willl help get this right, when I tell people I use iclone and... By planetstardragon ( 6 Years Ago )
Forum Post Thank you all for the feedback and for sharing your sometimes... By Peter (RL) ( 6 Years Ago )
Forum Post That would be great, Peter. In 3D Max there is a replace modifier... By Kelleytoons ( 6 Years Ago )
Forum Post Thank you Peter!! Your attention to this is sincerely appreciated, RL... By planetstardragon ( 6 Years Ago )
Forum Post I have long claimed there is a lot of room for "optimization" in... By justaviking ( 6 Years Ago )
Forum Post [quote][b]justaviking (8/10/2020)[/b][hr]Cleaning up technical debt is... By argus1000 ( 6 Years Ago )
Forum Post I agree that IClone's performance needs to be better. A lot better!... By james_muia ( 6 Years Ago )
Forum Post I agree with this whole thing, particularly what James said. I want to... By 3DChick ( 6 Years Ago )
Forum Post From what I am reading and seeing with the New CC3+ figures,... By AutoDidact ( 6 Years Ago )
Forum Post I agree with all of this. My processor and 128GB ram and two GTX 1080... By Shoob ( 6 Years Ago )
Forum Post Guys I fully agree with everything said here. It happens to me as... By Lamias ( 6 Years Ago )
Forum Post I think one feature RL could implement that would be fairly easy is a... By Kelleytoons ( 6 Years Ago )
Forum Post Except for the face sometimes, you don't need 4k textures for... By animagic ( 6 Years Ago )
Forum Post I am running a Ryzen 9 3900x on an x570 mobo. Previously had a GTX... By ultimativity ( 6 Years Ago )
Forum Post A program should be optimized to scale to current and next gen cards.... By greggoryaddison ( 6 Years Ago )
Forum Post By the way, if I remember correctly (can't search it now), RL says in... By Lamias ( 6 Years Ago )
Forum Post Let me weigh in here as well. I have been a faithful iClone user for... By Terry Miller ( 6 Years Ago )
Forum Post @Terry: I see you have a Quadro. Unfortunately that is not an... By animagic ( 6 Years Ago )
Forum Post Yes, I know the Quadro isn't the best for iClone. Unfortunately, this... By Terry Miller ( 6 Years Ago )
Forum Post I did a little testing yesterday , after considering the impact that... By planetstardragon ( 6 Years Ago )
Forum Post after running a few benchmarks, and monitoring my system performance... By planetstardragon ( 6 Years Ago )
Forum Post Try to work in "Quick Mode , Minimal Mode , or Custom Mode" ,... By StyleMarshal ( 6 Years Ago )
Forum Post I tried that yesterday actually - no difference in performance, but... By planetstardragon ( 6 Years Ago )
Forum Post I'm benching Iclone 7 today, - 7 is apparently using all 8 cores of... By planetstardragon ( 6 Years Ago )
Forum Post another fun discovery, I just got the out of memory error again on... By planetstardragon ( 6 Years Ago )
Forum Post The 30 fps with nothing in the view port is a bug discovered during... By animagic ( 6 Years Ago )
