wsessoms
wsessoms
Visits: 508
Hi, I ran across this YouTube video about using Alembic animations inside of iClone 7. The problem with the video is one it has no sound / dialogue and two the explanation as to how to get Alembic animations to work in iClone 7 is very vague. It would be very useful to be able to use Alembic animations in iClone. Below is the link to the YouTube video. Can you take a look at it and see if you can tell how he was able to get the Alembic animation to work in iClone and explain how he did it. I'm still learning the application and have no idea as to how this can be done but I would really appreciate any help with learning how to do this. https://www.youtube.com/watch?v=4qKw7cZHwpgThanks in advance for your help
Dell Precision T5500; Windows 10 Pro; Dual Xeon 5687 3.60GHz Processors; 72GB Ram; NVIDIA GeForce RTX 3080; Samsung 1TB SSD; Seagate 2TB 7200RPM HDD; Wacom Intuos Tablet; ASUS Dual Monitors
Posts: 5.3K,
Visits: 16.8K
Import Alembic is experimentally implemented in Python. Reference: https://wiki.reallusion.com/IC_Python_API:RLPy_RFileIOLoadAlembic function does not import mesh from the file and only loads animation. You have to have a respective mesh (which should completely match the one in .abc file) in iClone in order for it to work. It also only works on soft cloth. Thus it is very limited at the moment
wsessoms
wsessoms
Visits: 508
Thanks for the reply. Have you tried importing Alembic animation into iClone 7 using a python script? What I would like to do is import Alembic animation from Marvelous Designer into iClone 7. Thanks for the link. I'll check it out. In the process of learning Python. This would be a great plugin if it can be done.
Posts: 5.3K,
Visits: 16.8K
Yes, I have done that. The only problem is, I only was able to import alembic to props. I could not figure out how to import alembic directly to the soft cloth weighted to the avatar. There is no way to select a cloth via Python and using GetSelectedObjects function cannot get a hold of the cloth either. (If someone was able to pull this through, please post the code).
Here is how it applied to props:
And this is a script I was using:
import RLPy file_path = "PATH TO ALEMBIC FILE" object = RLPy.RScene.FindObject( RLPy.EObjectType_Prop, "Prop_Name" ) RLPy.RFileIO.LoadAlembicFile(object, file_path, RLPy.ECoordinateAxis_Y)
Note: Mesh name in the alembic file and the Mesh name of the prop it would be applied to MUST be the same. Prop_Name (and I think mesh names as well) are case sensitive!
wsessoms
wsessoms
Visits: 508
Thanks 4u2ges. That is very interesting. I'm am going to try to give it a go and see what I come up with. Will keep you updated on any progress. Thanks again!
Tugpsx
Tugpsx
Last Active: 3 hours ago
Visits: 410
Do i need 3DXChange pipeline for this exporter to work? i get <class 'NotImplementedError'>, when running the script.
Posts: 5.3K,
Visits: 16.8K
Tugpsx (8/7/2020) Do i need 3DXChange pipeline for this exporter to work? i get <class 'NotImplementedError'>, when running the script.Hmm, good question. I do not know. Maybe someone from RL dev team can answer that.
Posts: 15.8K,
Visits: 31.4K
4u2ges (8/7/2020)
Tugpsx (8/7/2020) Do i need 3DXChange pipeline for this exporter to work? i get <class 'NotImplementedError'>, when running the script.Hmm, good question. I do not know. Maybe someone from RL dev team can answer that. You do need 3DXchange Pipeline as that enables Alembic and other export functions in iClone.
ahingel
ahingel
Visits: 423
thank you for the script so much
but how do you create the .py file? do you export if from blender? im not good at all in code
thank you
ahingel
ahingel
Visits: 423
thank you
