pfitzuk
pfitzuk
Visits: 102
i get an error when linking in the unreal live link it says the node get subject data in the cclive link blueprint is depreciated does anyone know how to fix this thanks
oisilener1982
oisilener1982
Visits: 1.4K
Are you using 4.25 and is the CC/Auto live link turned on?
pfitzuk
pfitzuk
Visits: 102
yes and yes
oisilener1982
oisilener1982
Visits: 1.4K
I might be wrong but your screenshot does not show the Auto Setup Version 1.04 (Release Date: 2020-06-08) installed
AllenLee (RL)
AllenLee (RL)
Visits: 541
oisilener1982
oisilener1982
Visits: 1.4K
The CC Auto Livelink is either not Installed or Disabled in the Plugins
pfitzuk
pfitzuk
Visits: 102
yes its installed its just out of the screenshot 2 more icons to the left of live link but thanks
pfitzuk
pfitzuk
Visits: 102
cc auto is 1.04 and is installed and enabled livelink is installed 1.12 and enabled this was all updated then i transferred the character into unreal using the live link then i get this and it also does not transfer the shaders properly i had to go and manually update them
StyleMarshal
StyleMarshal
Posts: 5.8K,
Visits: 14.3K
I get the same "warning" but all is working fine here , I guess it has something to do with the frame rate linking. But I don't have your Error , "CCLiveLink_Blueprint_C is not valid" , why "C" ?
Also, when you transfer the Character via LL , you have to select your CC Character and tick the CC Setup afterwards to convert the shaders , when you import via fbx you don't have to do that.
Did you try "Apply Blueprint To Selected Character" under "IClone Live Link" for the Character that you imported via FBX ? Do you get the same Error then?
