Auto Setup 1.02 for Unity reverts animation changes
Posted By sabrx 5 Years Ago
sabrx
sabrx
Veteran Member (620 reputation)Veteran Member (620 reputation)Veteran Member (620 reputation)Veteran Member (620 reputation)Veteran Member (620 reputation)Veteran Member (620 reputation)Veteran Member (620 reputation)Veteran Member (620 reputation)Veteran Member (620 reputation)
Posts: 16, Visits: 86
Hello, the latest Auto Setup 1.02 for Unity 2019.3 (3D) reverts animation changes, even if the tool is turned off in Tools menu. Any changes I make to the animations (e.g. set Loop Time, Clamp Ranges etc.) are always reverted back despite confirming them. It must be the plugin that's doing this, because I reverted back to version 1.01 and it started to work again. I am using 3DXchange for exporting multiple animations, all in one file. It seems that the plugin is ignoring its enabled/disabled state and still working in background, which is undesired.
Threaded View
Threaded View
Forum Post Auto Setup 1.02 for Unity reverts animation changes By sabrx ( 5 Years Ago )
Forum Post Hi sabrx, We are checking the issue now. Thanks for reporting! By Miranda (RL) ( 5 Years Ago )
Forum Post Great, I hope it will be resolved soon. You could also have a look at... By sabrx ( 5 Years Ago )
Forum Post Hi sabrx, It's confirmed that the settings are not applied as you... By Miranda (RL) ( 5 Years Ago )
Forum Post Hi Miranda, thank you for your suggestion, but that's not good... By sabrx ( 5 Years Ago )
Forum Post With CC3 you can export as much Animations as you want with the... By StyleMarshal ( 5 Years Ago )
Forum Post Thank you, I never noticed this feature in CC 3, because I... By sabrx ( 5 Years Ago )
Forum Post 3dxchange is good for converting different meshes or skeletons into... By StyleMarshal ( 5 Years Ago )
Forum Post OK, good to know - I didn't use it for this purpose yet. But it is... By sabrx ( 5 Years Ago )
Forum Post [quote][b]sabrx (6/15/2020)[/b][hr]Hi Miranda, thank you for your... By luke (RL) ( 5 Years Ago )
Forum Post Hi Miranda, was this problem ever resolved? I am having similar issues... By bmacdonald1986 ( 4 Years Ago )
Forum Post I can confirm that version 1.1 works flawlessly in Unity 2019.3.13f1.... By sabrx ( 4 Years Ago )
Forum Post May you double check the settings that sabrx mentioned? Open the... By Miranda (RL) ( 4 Years Ago )
Forum Post Hi - I am experience the same animation import settings problem Is... By michael_571550 ( 5 Years Ago )
Forum Post The workaround is to switch back to 1.01 :-) By sabrx ( 5 Years Ago )
Forum Post [quote][b]sabrx (6/27/2020)[/b][hr]The workaround is to switch back to... By Miranda (RL) ( 5 Years Ago )
Forum Post Hi, The tool actually impact FBX that I import in my project even... By Necka ( 5 Years Ago )
Forum Post [quote][b]Necka (6/29/2020)[/b][hr]Hi, The tool actually impact FBX... By Miranda (RL) ( 5 Years Ago )
