Auto Setup 1.02 for Unity reverts animation changes
Posted By sabrx 5 Years Ago
Miranda (RL)
Miranda (RL)
Distinguished Member (68.7K reputation)Distinguished Member (68.7K reputation)Distinguished Member (68.7K reputation)Distinguished Member (68.7K reputation)Distinguished Member (68.7K reputation)Distinguished Member (68.7K reputation)Distinguished Member (68.7K reputation)Distinguished Member (68.7K reputation)Distinguished Member (68.7K reputation)
Posts: 1.8K, Visits: 11.2K
May you double check the settings that sabrx mentioned?
Open the Settings panel (Tools menu > Character Creator & iClone Auto Setup) to make sure the "Auto-Processing" option is unchecked.
sabrx
sabrx
Veteran Member (620 reputation)Veteran Member (620 reputation)Veteran Member (620 reputation)Veteran Member (620 reputation)Veteran Member (620 reputation)Veteran Member (620 reputation)Veteran Member (620 reputation)Veteran Member (620 reputation)Veteran Member (620 reputation)
Posts: 16, Visits: 86
I can confirm that version 1.1 works flawlessly in Unity 2019.3.13f1. Maybe you have Auto-processing enabled during the editing. You better disable it and then do the changes.
bmacdonald1986
bmacdonald1986
Junior Member (226 reputation)Junior Member (226 reputation)Junior Member (226 reputation)Junior Member (226 reputation)Junior Member (226 reputation)Junior Member (226 reputation)Junior Member (226 reputation)Junior Member (226 reputation)Junior Member (226 reputation)
Posts: 14, Visits: 123
Hi Miranda, was this problem ever resolved? I am having similar issues now with modifying animations to loop in Unity. When you apply the settings to the FBX import, the settings are reverted to the import default (no looping).
Thanks
Miranda (RL)
Miranda (RL)
sabrx (6/27/2020)
The workaround is to switch back to 1.01 :-)
Hi sabrx, michael and others,
It's fixed in version 1.1. Please download the tool, and try again, thank you!
Miranda (RL)
Miranda (RL)
Necka (6/29/2020)
Hi,
The tool actually impact FBX that I import in my project even though they are not Iclone/CC related and are not imported in the CC Asset folder.
The tool is touching things it should not, I hope you can fix that soon
Hi Necka!
https://www.reallusion.com/character-creator/unity-auto-setup.html
Necka
Necka
Veteran Member (569 reputation)Veteran Member (569 reputation)Veteran Member (569 reputation)Veteran Member (569 reputation)Veteran Member (569 reputation)Veteran Member (569 reputation)Veteran Member (569 reputation)Veteran Member (569 reputation)Veteran Member (569 reputation)
Posts: 62, Visits: 407
Hi,
sabrx
sabrx
michael_571550
michael_571550
Junior Member (155 reputation)Junior Member (155 reputation)Junior Member (155 reputation)Junior Member (155 reputation)Junior Member (155 reputation)Junior Member (155 reputation)Junior Member (155 reputation)Junior Member (155 reputation)Junior Member (155 reputation)
Posts: 6, Visits: 331
Hi - I am experience the same animation import settings problem
Is there any workaround for now? Any ETA on the fix?
Thanks
luke (RL)
luke (RL)
Group: Power Developer
Posts: 289, Visits: 5.6K
sabrx (6/15/2020)
Hi Miranda,
thank you for your suggestion, but that's not good workflow - iClone is able to export only 1 animation with a character, right? That means I would have to export them one by one, which is very impractical and there are also space limitations - if one CC character takes about 100 MB, then that would be 10 GB for 100 animations, which is an overkill. My current workflow is to export a character twice - once from CC or iClone without animations and once from 3DXChange with all animations included, and then remap animations in Unity. If there is a better workflow to do this, please tell me.
Best,
Erich
You can delete all the textures for saving space. And I made a small plugin for iClone which can allow you to export multiple fbx in the same time.
https://youtu.be/s2MGg9O6BhQ
and here is the script
https://drive.google.com/file/d/1mtpF50kv-ub71wWn8yTwV3iGZe5o8qm9/view?usp=sharing
I hope it helps you, thanks
sabrx
sabrx
OK, good to know - I didn't use it for this purpose yet. But it is quite crazy that iClone is animation software and doesn't allow you to export multiple animations and CC 3 is designed for character modeling and allows you to do that.
