Character Backwards when linked up in Unreal
Posted By psnryan 5 Years Ago
psnryan
psnryan
Junior Member (216 reputation)Junior Member (216 reputation)Junior Member (216 reputation)Junior Member (216 reputation)Junior Member (216 reputation)Junior Member (216 reputation)Junior Member (216 reputation)Junior Member (216 reputation)Junior Member (216 reputation)
Posts: 2, Visits: 15
Hi all,
Hoping someone has an answer or quick fix for this issue.
Live Link works great for any character that comes with Iclone, but when I use my custom character the motion in Unreal is facing the opposite direction to in Iclone.
Animation still works on the hands, legs arms etc, its just the root seems to be reversed in Unreal.
You can see what I mean here:
https://forum.reallusion.com/uploads/images/3bf81b94-a784-4fb9-87c0-ddb1.png
https://forum.reallusion.com/uploads/images/ca2caa00-d1aa-4de1-8fac-4162.png
I'm new to using animation with unreal so is there a quick fix to this, or have I just messed up some import options?
Many Thanks!
V
StyleMarshal
StyleMarshal
Distinguished Member (14.4K reputation)Distinguished Member (14.4K reputation)Distinguished Member (14.4K reputation)Distinguished Member (14.4K reputation)Distinguished Member (14.4K reputation)Distinguished Member (14.4K reputation)Distinguished Member (14.4K reputation)Distinguished Member (14.4K reputation)Distinguished Member (14.4K reputation)
Posts: 5.8K, Visits: 14.3K
I've seen this issue with Maya Live-Link.
Here is an Idea , don*t know if it works:
1. Bring in an Empty Actor (or a Live Link Origin)
2. Parent your Character under the Empty Actor (only the Character that is reversed)
3. Rotate the Empty Actor by 180 degrees
https://forum.reallusion.com/uploads/images/84e086f4-8135-447a-83b2-d1fe.jpg
unit23
unit23
Posts: 115, Visits: 380
You can also open the character blueprint and adjust the rotation there on the Z axis. Unreal characters are usually set to rotate -90 or 270 (same).
When moving content into Unreal and character rotation is not corresponding to animations, you may want to re-import the character mesh with altered rotation, set under import settings, on the character mesh panel.
psnryan
psnryan
Thanks I'll have a look at both of these!
I tried removing the origin and re-importing then parenting everything into it separately but that unfortunately didn't work. I'll try rotating the origin and then parenting next.
I shall also try the import settings and adjusting the blueprint.
I'll update you once I have given them a go, hopefully they work!
Eric C (RL)
Eric C (RL)
Distinguished Member (11.8K reputation)Distinguished Member (11.8K reputation)Distinguished Member (11.8K reputation)Distinguished Member (11.8K reputation)Distinguished Member (11.8K reputation)Distinguished Member (11.8K reputation)Distinguished Member (11.8K reputation)Distinguished Member (11.8K reputation)Distinguished Member (11.8K reputation)
Posts: 552, Visits: 6.0K
psnryan (4/24/2020)
Hi all,
Many Thanks!
V
Hello @psnryan,
We would suggest you file the feedback tracker, and also provide us the project download link.
Our team should take a closer look and help you out. Here's the link below:
https://www.reallusion.com/FeedBackTracker/MyNew
Eric
