Can't locate or open Bump and Displacement maps
Posted By plan111 5 Years Ago
plan111
plan111
Last Active: 8 Months Ago
Posts: 80, Visits: 226
Actually I just discovered an easier way that doesn't involve any photo editor. Just select the bump map and check Flip Normal Y.
https://forum.reallusion.com/uploads/images/2a778f28-e759-4da5-829b-71c6.png
plan111
plan111
Thanks 4u2ges. It worked. Inverted the bump map and voilà, a "normal" baseball.
https://forum.reallusion.com/uploads/images/77005613-112e-4c5e-b2aa-36ae.png
Posts: 5.3K, Visits: 16.8K
Notice, the  texture slots have that red icon. This means the substance texture is not baked (you can still edit it in substance section).
You may individually bake selected texture with "Bake Substance Texture" button in materials section.
Or globally from Edit menu.
plan111
plan111
Hi.
For this baseball, I’m exporting the BaseColor (diffuse) from Filter Forge and generating the rest of the maps withiCLone’s B2M from Substance Super Tools. As you can see, the bump map isinverted in the lower stitching, (or is that the Displacement, I’m not sure).It’s creating a crease instead of a bump. Usually when I select one of themaps, I can click on the “Launch” button to edit the map in Photoshop orAffinity, but now the button’s greyed out. If I select the Opacity map, thebutton is not greyed out anymore. I tried saving all the maps (Save AllMaterial Textures), but it just gives me solid colors. Also, I can’t see any“Find File” option for any of the maps, as I get when right-clicking a prop. Isthere a way I can locate the map in explorer, or open it in a photo editor inany way?
So , if I can get a way to open or save themaps, which ones do I need to invert? Bump? Displacement? Both?
Thanks.
https://forum.reallusion.com/uploads/images/32c49235-d05d-4d8e-84a9-7410.png
