danielmontaguejohnson
Visits: 82
Hello and good morning, I am having the hardest time and I cant seem to figure this out for the life of me, so I am hoping that you can lend me some guidance? I just purchased the dForce African Hair for Genesis 8https://www.daz3d.com/dforce-african-hair-for-genesis-8-femaleand whenever I try to export it and bring it into character creator, the only thing that will come in is the "head cap" a piece that the hair is supposed to connect to I guess. I amlost got it once, the hair came in as dots and not full length strands of hair. any help would be greatly appreciated. feel free to contect me on my personal email as well thank you for your time and consideration
Visits: 22.1K
I wrote you to privately, but for the benefit of others I'll also respond here. You're unlikely to be able to use this hair. It isn't polygonal, and thus even if you could get it into CC (which I doubt) it would either crash your system or bring it to its knees. It's just not the right kind of hair to animate -- the absolute best you could do would be to drastically reduce it using the tools inside of CC but then it wouldn't look very good. Sorry, but this just isn't the kind of hair animation works well with.
Visits: 82
you are the man, I appreciate the reply. So, in this case, is there another way I could get something like this in iclone | cc maybe as an accessory or a prop?
thanks again
Visits: 82
do you think that I would I have the same problems with this ? https://www.daz3d.com/short-afro-hair-for-genesis-3-and-8
Lord_Dreadmoor
Lord_Dreadmoor
Visits: 2.4K
Daz hair is often tricky and requires different import and export tweaks, depending on the particular mesh setup. After some experimentation, I found that there's actually a way around the error with "afro" styled hair. When you import your figure, follow these steps and let me know if this works for you. Be sure to check ADVANCED when bringing your character in. 76% of original size (was 662x19) - Click to enlarge Then be sure to leave your cap as CLOTH, but change your hair itself to HAIR. I personally always change highly detailed meshed to either 2K or 4K in size as well, but that's a matter of personal preference. 76% of original size (was 662x19) - Click to enlarge Now you'll notice an unnecessary amount of "sheen" on both the cap and the hair itself. That's because the original modeler made this mesh with rendering in DAZ in mind, not Reallusion, but it's a relatively easy fix. 76% of original size (was 662x19) - Click to enlarge First, you select the cap, go to the materials, select roughness, open your color adjust and then push your roughness slider all the way to the right until it maxes out white. This will remove the shine from the scalp that will show through on any renders. 76% of original size (was 662x19) - Click to enlarge 76% of original size (was 662x19) - Click to enlarge Next, what I like to do is select the hair mesh itself, go to materials and be sure to hit control and select both hair materials, then open your color adjust and up the roughness to about 30, otherwise your afro will render with more of a "Soul-Glo". Jheri Curl look, and since this isn't the early 1980's... just no, lol. 76% of original size (was 662x19) - Click to enlarge Now, you go ahead and switch all of your hair, skins, eyes and teeth to DHS, hit your render and you should be right as rain. 76% of original size (was 662x19) - Click to enlarge Hopefully this helps.
artstation.com/dreadmoormediaarts
Visits: 82
SO first off, I want to say... this is my first time using a forum. But you guys have made my fist experience doing so Amazingly Amazing! I really Appreciate all of the help!
I am off work in an hour and as soon as I get in, I will check it out and give you all follow ups.
Much love and appreciation
Visits: 82
Ok, so I’m really messing something up. Whenever I export from Daz, I only get the head cap, no hair in the list of things being imported. Only one time I was able to have it come over in the list of items that was being imported, and some sliders actually came over, but the hair came in as dots, at where the tips of the hair would be.
Thanks again
Lord_Dreadmoor
Lord_Dreadmoor
Visits: 2.4K
danielmontaguejohnson (3/12/2020) Ok, so I’m really messing something up. Whenever I export from Daz, I only get the head cap, no hair in the list of things being imported. Only one time I was able to have it come over in the list of items that was being imported, and some sliders actually came over, but the hair came in as dots, at where the tips of the hair would be.
Thanks again Can you take a screenshot of your export panel in Daz so we can see what you have selected. Perhaps even something is messed up when you attach the hair to your figure. I would need to know your step by step process to be able to pinpoint where the error is. Feel free to send me a direct PM and we will see if we can get you sorted out.
Visits: 82
Lord_Dreadmoor
Lord_Dreadmoor
Visits: 2.4K
I see your problem right away. I just PM'd you.
