Smart gallery does not work
Posted By waynewiz16 5 Years Ago
Ascensi
Ascensi
Posts: 262, Visits: 1.9K
Interesting.. I had to use this patch before the recent update of CC3 3.41 and iClone, everything was working fine then after the update it stopped working so here I am again and applied the fix and it's working again. Maybe Reallusion should add this reset in the installers for the last operation.
Store Page Link
AMD 4.5 GHz 16 Cores  | 128 GB | RTX 4090 | Window11 | Houdini FX 18.5 | Zbrush 2023 | Maya 2014 | Adobe CS6 | Sonar Producer X3 | iC8, CC4 | DTS Master Audio Suite | Perception Neuron 32 Alum Edition | Akeytsu
irina-04602007
irina-04602007
Posts: 19, Visits: 1.6K
Thanks a lot! That solved my problem!
waynewiz16
waynewiz16
Senior Member (489 reputation)Senior Member (489 reputation)Senior Member (489 reputation)Senior Member (489 reputation)Senior Member (489 reputation)Senior Member (489 reputation)Senior Member (489 reputation)Senior Member (489 reputation)Senior Member (489 reputation)
Last Active: 6 days ago
Posts: 11, Visits: 196
I ran the debug tool and reset the database.
The Doomsday pack does not appear in  Iclone 7.7.2, but it does now appear in CC 3.2.2.
I cannot find the folders
C:\ProgramData\Reallusion\CMS  and
 C:\ProgramData\Reallusion\ContentManager\MetaCache
DxDiag.txt (735 views, 117.00 KB)
DESKTOP-4JFJJ55.LOG txt.txt (324 views, 62.00 KB)
Edward (RL)
Edward (RL)
Posts: 301, Visits: 4.9K
waynewiz16 (2/25/2020)
I installed Smart Gallery in Iclone 7.72 ans CC 3.22 but it does not work. I bought Doomsday Playset but it does not show uo in Smart content.
There is no other way to install it.
In fact the plugin is extremely sluggish and unresponsive. It is stuck on "trial" in CC.
I cannot select anything else in the SC window.
Hello,
Cause we cannot reproduce this issue in our test environment.
We need your help with providing below extra data:
The system info (registry, dxdiag.txt...) Please ref this FAQ to get it.
The local database and cache files
1. Database: compress this folder %ProgramData%\Reallusion\CMS as a .zip file
2. Metacache: compress this folder %ProgramData%\Reallusion\ContentManager\MetaCache as a .zip file
The .log file (ref the video)
1. Uncompress and run the attached Debugview tool.  (Dbgview.zip
2. Run iClone or Character Creator, till the Smart Gallery syncing finished.
3. Send us the log file by clicking Save in the Debugview.
And if you need to continue your work immediately, you may try resetting your database by executing the attached Reset DB_OfficialSG.bat with the administrator.
Make sure your IC/CC is not running when you are executing the .bat.
After that restart the IC/CC program.
If the issue still existing, please remove the Smart Gallery via Reallusion Hub, waiting for our further answer to your problem.
Edward
Dbgview.zip (710 views, 392.00 KB)
Reset DB_OfficialSG.zip (944 views, 315 bytes)
waynewiz16
waynewiz16
