Mikie123
Mikie123
Visits: 240
I created cc3 character for unreal 4.23.1 and gave it some animations. An idle. When I put the character into 4.23(idle) one of the arms was slightly inside of the body. So I modified the character by moving the arms away from the body a little. And save it. This did not help. Didn't help. Is there anyway to fix the problem? Thanks.
unit23
unit23
Visits: 380
Mikie123 (1/17/2020) I created cc3 character for unreal 4.23.1 and gave it some animations. An idle. When I put the character into 4.23(idle) one of the arms was slightly inside of the body. So I modified the character by moving the arms away from the body a little. And save it. This did not help. Didn't help. Is there anyway to fix the problem? Thanks. Did you setup all your Unreal import settings as given in this howto? https://manual.reallusion.com/CC_and_IC_Auto_Setup_Plugin/ENU/CC_and_iC_Auto_Setup/1.0/02_for_Unreal/Importing_Character_FBX_File.htm For instance did you set Use T0 As Ref Pose?
