character
https://forum.reallusion.com/Topic433620.aspx
Print Topic | Close Window
By Mikie123 - 6 Years Ago
I created cc3 character for unreal 4.23.1 and gave it some animations.  An idle.  When I put the character into 4.23(idle) one of the arms was slightly inside of the body.  So I modified the character by moving the arms away from the body a little.  And save it.  This did not help.  Didn't help.  Is there anyway to fix the problem?  Thanks.
By unit23 - 6 Years Ago
Mikie123 (1/17/2020)
Did you setup all your Unreal import settings as given in this howto? https://manual.reallusion.com/CC_and_IC_Auto_Setup_Plugin/ENU/CC_and_iC_Auto_Setup/1.0/02_for_Unreal/Importing_Character_FBX_File.htm For instance did you set Use T0 As Ref Pose?
