RLord321
RLord321
Last Active: 10 Months Ago
Visits: 97
In Character Creator 3.1, I was able to fumble my way though exporting a character as a PNG image with a transparent background. I disabled the image for the scenes and did other things that I cannot remember and it was successful. I cannot replicate this in version 3.2. Does anyone know the exact steps to export a PNG with a transparent background (I'm assuming this feature was not removed in this version)?
Visits: 22.1K
In your Edit/Project Settings there is a 2D background rollout. Just uncheck the background image.
RLord321
RLord321
Visits: 97
Thanks Kellytoons. I initially still had the problem after your reply of: - From the Edit Menu, select Project Settings - Under the 2D Background Rollout, De-Select "Activate Image"
It turns out that I also had to turn off the "Show Sky" visibility by doing: - From the Windows Menu, select Visual Settings - In the Image Based Lighting Rollout, click on the invisible icon next to Show Sky
And this works when I actually click on Export from the Render menu and actually export using the export button (as opposed to the Preview Image option under the Render menu -- this will not produce the transparent background).
I hope this helps anyone else who currently has this problem.
Again, Thanks!
