dsimovski
dsimovski
Visits: 204
Sooo .... it s the Limitation of the trial that seems to do that. I remember having a trial installed 1-2 years ago where i used all my export Limits (englisch version). As i now wanted to try it again, the German version said i have again 15 Times saving left. But thats not true ;) It Doesnt export - it crashes ;) I installed the englisch version and that said 0 times left.
Ok - i bought it and it works fine now ;) Thanks for the time
yours Damir
Posts: 23.1K,
Visits: 36.6K
dsimovski (11/8/2019) Hi, Installed it on another Computer and got the same issues (totally different Hardware). May be its the Trial ? Is there someone who can test win10 without 3D Exchange License. Just install the trial and export a standard avater as FBX with Unity Preset.
yours Damir
Thanks for doing further tests. It does indeed appear a trial version issue as the full version is working fine. I will pass this on for further investigation. Apologies for the inconvenience, but if you do decide to purchase you should have no problems with the export to Unity in the full version.
welchg
welchg
Last Active: 6 Years Ago
Visits: 10
I am having the same issues with iClone 7 Trial crashing with all FBX exports... have re-installed a few times as well. Contacted tech support several times, no fix. Can someone please confirm this is a trial version issue? I need to recommend to my boss to purchase or not, cant recommend an app that doesn't export what we need to Unity. As a work around, I used a Character Creator to Unity FBX export, but this work flow only applies to the supported human model type that CC will open, and not non standard characters saved as an avatar file, like a teddy bear.
dsimovski
dsimovski
Visits: 204
yours Damir
dsimovski
dsimovski
Visits: 204
reinstalling didnt help either :/
dsimovski
dsimovski
Visits: 204
Thank you,
i already tried deactivating all Settings. It didnt help. Even without all Options flagged it just crashes. An Installation issue could be the case. I reinstall 3d Exchange.
yours Damir
ps: Support Ticket is open
Posts: 23.1K,
Visits: 36.6K
Thanks for explaining more. If the Max preset works fine then it looks like one of the Advanced settings used for Unity may be causing the crash. You could try opening the "Advanced Settings" panel (see below) and try unchecking the Embed Motion option for Unity. Then try exporting again. You could also do the same with the other options until you find what is causing the crash. You may also like to try uninstalling 3DXchange 7 and reinstall again (with iClone closed down) to eliminate a problem with the install. If you continue to have problems after that, please contact Technical Support using the link below and let them have your dxdiag.txt so they can check for any problems with drivers etc. https://www.reallusion.com/CustomerSupport/UserEx/QForm.html
dsimovski
dsimovski
Visits: 204
Hi Peter. i can export with the Max Preset fine. I dont get an error message :/ it doesnt even start showing the export. Just the blue Circle and gone. Here is a screencap: https://www.dropbox.com/s/kyzbwntqkgonaq5/IcloneCrashOnExport.mp4?dl=0yours Damir
Posts: 23.1K,
Visits: 36.6K
Hi Damir I just tested with the Base Female avatar using the Unity preset and it exported fine from iClone 7.61. Are you able to export using a different preset like Max or Maya or does it crash with them also? Also do you get an error message with the crash? If so can you post a screenshot of it.
dsimovski
dsimovski
Visits: 204
Hi all, i am fairly new to Iclone and evaluating fbx export directly from Iclone (with the 3D Exchange trial). It crashes everytime i want to export a FBX with the unity preset. To Reproduce you can Open Iclone Load the Base Female.IAvatar Select it export fbx with the Unity3D Preset Crash can someone confirm this ? What can i do ? yours Damir
