How to know the scale or the measure of the objects in the projects
Posted By edycrp 6 Years Ago
Posts: 15.8K, Visits: 31.4K
BenjaminTuttle (11/7/2019)
One thing that can be done is simply make a meter cube.
iClone's built-in Box shape is actually suited for that, as it has sides of 1 meter.
EDIT: There is also a free ruler in the Market Place: https://marketplace.reallusion.com/ruler. It's in feet, but you can make it metric by re-texturing.
4413Media
4413Media
Last Active: 8 Months Ago
Posts: 394, Visits: 7.4K
As previously mentioned, iclone's basic unit of measurement is the centimeter.
Blender's default is also metric. The default cube for blender is 2 meter  x 2 meter  x 2 meter. Scale it by 50 percent and you can use it as a form of measurement as a basic measurement. Be sure to export as an fbx for 1 to 1 scale when you import to iclone.
iClone Certified Director and makes miserable Westerns.
edycrp (11/7/2019)
Exactly, it makes no sense that this program does not have a system of measures to compare an object with respect to another. A very notable error which I do not understand because they have not sought to solve it.
Exacto, pues no tiene sentido que este programa no tenga sistema de medidas para poder comparar un objeto con respecto a otro. Un error muy notable el cual no entiendo porque no la han buscado solucionar.
I disagree that it is an error. It would be a useful feature, but over the years I haven't seen many requests for it (if any). It's up to you to enter a feature request. That is in general how things move along in iClone.
I have built many sets for my movies, and I make sure the various props are at the right scale. That isn't too hard to do.  After that combining the individual objects is not complicated.
edycrp
edycrp
Veteran Member (532 reputation)Veteran Member (532 reputation)Veteran Member (532 reputation)Veteran Member (532 reputation)Veteran Member (532 reputation)Veteran Member (532 reputation)Veteran Member (532 reputation)Veteran Member (532 reputation)Veteran Member (532 reputation)
Posts: 9, Visits: 282
Rockoloco666
Rockoloco666
Group: Banned Members
Posts: 762, Visits: 2.0K
Modelling or not measures would be very useful when putting sets together for example
The info option in CC (Ctrl+F) shows the height of the character or any part that has been selected. So that's at least something.
Dragonskunk
Dragonskunk
Distinguished Member (8.2K reputation)Distinguished Member (8.2K reputation)Distinguished Member (8.2K reputation)Distinguished Member (8.2K reputation)Distinguished Member (8.2K reputation)Distinguished Member (8.2K reputation)Distinguished Member (8.2K reputation)Distinguished Member (8.2K reputation)Distinguished Member (8.2K reputation)
Posts: 368, Visits: 1.4K
Is there that yellow figure to measure the average human from 3DX in iClone?
Often, I wish there were one so that I don't have to find an average human avatar to drag into a scene.
I guess I could just make one.
https://forum.reallusion.com/uploads/images/f0d5a6aa-f907-4e06-b7ab-3cc3.jpg
The unit of measurement as you see for the position of an object is centimeters. The default grid size is 100, which is equivalent to 1 meter, but the grid size can be changed in Preference.
As Raxel points out, dimensions of objects are not specified as numerical values, similar to what we have for position, so for now we have to use workarounds.
If iClone were a modeling program, there would of course be more of a need. There is a Feedback Tracker were you can make feature requests, or perhaps this has already been requested in the past.
edycrp
edycrp
Muchas gracias compañero, es por lo menos algo con que contar, pero la verdad que es una porquería eso de que las cosas no tienen una medida, pues asi uno no puede hacer objetos de manera correcta sino que todo es al calculo o al ojo.
Sabes que, voy a exponer eso en este foro, para ver si los ingenieros del sistema implementan un sistema de medida para el programa.
Gracias por la cooperación...
Rockoloco666
Rockoloco666
Lamento informarte que no hay una forma simple y sencilla de saber cuanto mide un objeto en iclone, lo cual francamente es una mierda, la unica forma es construyendo una regla primitiva usando el grid (rejilla) que esta subdividida en metros, cada cuadro de la rejilla mide 1m cuadrado. Es algo que es bastante necesario pero no lo han implementado
