Donald24433 (10/18/2019)
While trying to use CTA 4.1 new PSD function loading in Affinity Designer I get two errors :
Failed to open PSD file
"PC\AppData\Local|Temp\CTA4Temp\PSD_Cache\Default(0).psd The file was not found."
and
Failed to open file
"C:\Users\Donald The filed not found."
Designer will load and open followed by the above error panels. Is it most likely an error in the program or my system?
Thank YouCould you share your screenshot?
I have Designed too, but it doesn't happen this issue.
Or you can pass this issue to Technical support.
https://www.reallusion.com/CustomerSupport/User/FAQList.html
