CA 4.1 Affinity Designer
Posted By Donald24433 Last Year
Donald24433
Donald24433
Posted Last Year
Senior Member (290 reputation)Senior Member (290 reputation)Senior Member (290 reputation)Senior Member (290 reputation)Senior Member (290 reputation)Senior Member (290 reputation)Senior Member (290 reputation)Senior Member (290 reputation)Senior Member (290 reputation)
Posts: 7, Visits: 21
While trying to use CTA 4.1  new PSD function loading in Affinity Designer  I get two errors :
Failed to open PSD file
"PC\AppData\Local|Temp\CTA4Temp\PSD_Cache\Default(0).psd     The file was not found."
and
Failed to open file
"C:\Users\Donald   The filed not found."
Designer will load and open followed by the above error panels.  Is it most likely an error in the program or my system?
Thank You
ms12
ms12
Posted Last Year
Veteran Member (827 reputation)Veteran Member (827 reputation)Veteran Member (827 reputation)Veteran Member (827 reputation)Veteran Member (827 reputation)Veteran Member (827 reputation)Veteran Member (827 reputation)Veteran Member (827 reputation)Veteran Member (827 reputation)
Posts: 32, Visits: 537
Are you using an official release of CTA 4.1? I too use CTA, however, I don't see 4.1 available.
Donald24433
Donald24433
Posted Last Year
I used the update found under the help tap in CTA.  This took me to the update page.
Donald24433
Donald24433
Posted Last Year
This does indicate it is for Pipeline only.   So if you don't have Pipeline you may not see this update.
kylelee
kylelee
Posted Last Year
Posts: 354, Visits: 3.3K
Donald24433 (10/18/2019)
and
Failed to open file
Thank You
Could you share your screenshot?
I have Designed too, but it doesn't happen this issue.
Or you can pass this issue to Technical support.
https://www.reallusion.com/CustomerSupport/User/FAQList.html
Last Year by kylelee
Donald24433
Donald24433
Posted Last Year
https://forum.reallusion.com/uploads/images/bfb17b41-9281-408d-97a3-79df.jpg
