Just published Photorealistic Water and Wave Maker Combo pack in the MarketPlace
Posted By Ascensi 6 Years Ago
Just published Photorealistic Water and Wave Maker Combo pack in the...
toystorylab
toystorylab
Distinguished Member (17.3K reputation)Distinguished Member (17.3K reputation)Distinguished Member (17.3K reputation)Distinguished Member (17.3K reputation)Distinguished Member (17.3K reputation)Distinguished Member (17.3K reputation)Distinguished Member (17.3K reputation)Distinguished Member (17.3K reputation)Distinguished Member (17.3K reputation)
Posts: 4.6K, Visits: 29.9K
Ascensi (10/10/2019)
I'm working on boat physics update so basically the waves will influence the boat, or maybe dead bodies floating in your case ;)
and I think just simply having a path for the boats to follow will allow freedom for boat physics!
That would be very cool, as it is very tedious and tricky to fake that cause you can't see the waves as you scrub the timeline...
charly Rama
charly Rama
Distinguished Member (8.1K reputation)Distinguished Member (8.1K reputation)Distinguished Member (8.1K reputation)Distinguished Member (8.1K reputation)Distinguished Member (8.1K reputation)Distinguished Member (8.1K reputation)Distinguished Member (8.1K reputation)Distinguished Member (8.1K reputation)Distinguished Member (8.1K reputation)
Posts: 1.9K, Visits: 17.3K
Thank you guys, this is my next acquisition. Very big potential
Ascensi
Ascensi
Posts: 262, Visits: 1.9K
toystorylab (10/10/2019)
Thanx for the brilliant idea...
I took the plunge, bought it and gave it a try.
Here is my first result:
That's good enough for me to get some ocean in my movies... Thanx ;)
That's pretty cool! Very stylized. Thanks for sharing, your the first to show it off.  I'm working on boat physics update so basically the waves will influence the boat, or maybe dead bodies floating in your case ;) and I think just simply having a path for the boats to follow will allow freedom for boat physics!  I just thought of now, if you have a moment would you mind giving it a rating and maybe a review?  Thanks again for your support and sharing your work!
Store Page Link
AMD 4.5 GHz 16 Cores  | 128 GB | RTX 4090 | Window11 | Houdini FX 18.5 | Zbrush 2023 | Maya 2014 | Adobe CS6 | Sonar Producer X3 | iC8, CC4 | DTS Master Audio Suite | Perception Neuron 32 Alum Edition | Akeytsu
toystorylab
toystorylab
Ascensi
Ascensi
I'm currently rendering  out another video with a Lady in the water to give perspective.. I'll will add camera angles/animation later such as looking top-down from the cliff as she scales it. Right now I've applied an early bird price @ 30% off until Nov 1st.
I don't want to use up all my time for rendering though.. I have another challenge -surfing wave!
Store Page Link
charly Rama
charly Rama
It looks very promising, like Kevin, I'm waiting for more convincing videos before buying this, I  think there are lot of improvements you can do for this , very interesting anycase
Ascensi
Ascensi
Kevin.S (10/9/2019)
Some free advice ;)
Before you charge people $10.00 for this you may want to explain more about it how it works etc
Maybe show a demo video of it being used in iclone the set up etc.:D
Does it work with the current water system?
Can you adjust the water like the current system?
Can you change the water direction size height
It says you can use it in CC how ?
etc etc etc...
You state in your own txt on the store
I haven't tried using the iClone water textures, maybe they are better?
Tip
Selling something you haven't even tried your self is just not a wise thing :D
Also this is the showcase artwork section of the forum not products :D
Hi thanks! yes I realize the info needs to be refined.. a lot of what you were inquiring about is actually listed in the txt file and in the description. The description area had limited what i wanted to post. To answer your questions is yes you can alter the speed, wave height.. I haven't used Reallusions water textures because I was making something for IRAY to begin with and I'm not including their water textures. I've used the iClone water but wasn't compatible with IRAY so I made something that does work.  The wave system also works with iClone.   About show casing portfolio, yes I found the right thread after this post. This "system" is a plane with UV animation but many other settings and physics setup, it's just a practical way to make things work. When someone loads the project and presses play they will immediately see it work. Unfortunately for me if I created a demo of using it in iClone it would expose many settings that would allow another to reproduce.. so instead I do provide the settings such as specific material channel,physics and tools/models that can be changed for different scenarios and what must not be changed. I could make a private video tutorial that becomes available after purchase and will probably look into that soon. Thanks for the heads up :)
Store Page Link
Kevin.S
Kevin.S
Distinguished Member (10.8K reputation)Distinguished Member (10.8K reputation)Distinguished Member (10.8K reputation)Distinguished Member (10.8K reputation)Distinguished Member (10.8K reputation)Distinguished Member (10.8K reputation)Distinguished Member (10.8K reputation)Distinguished Member (10.8K reputation)Distinguished Member (10.8K reputation)
Posts: 1.2K, Visits: 71.8K
Some free advice ;)
etc etc etc...
Tip
Freelance Artist Kevin.S
https://forum.reallusion.com/uploads/images/57cedd8e-58c4-42ce-b2f4-9646.png https://forum.reallusion.com/uploads/images/5a59e070-66a0-4914-b0a5-b2dc.png
Email: animatemyart@gmail.com - Web Site:  www.animatemyart.com
Ascensi
Ascensi
Hi everyone, this is our first product I hope you give it a try. Store page Link
https://forum.reallusion.com/uploads/images/b3760268-b7ea-4859-ad17-4e3d.png
Store Page Link
